Idle still too high
Old Oct 14, 2002 | 06:20 PM
WrenchHead84's Avatar
WrenchHead84
Post Idle still too high
My idle is still around 1000 rpm's. I've taken my carb off and looked at the butterfly valve. Nothing is catching, or preventing it from closing. My high idle is not interfering with my curb idle, and my curb idle screw is so far back it's not even touching the throttle lever. My choke is fully open at warm up temps. According to the chiltons manual I think it says 700 rpm's at curb idle.
Any ideas would be helpful...
WrenchHead
1979 F-150 Custom. 302 V-8 4-spd 2WD. 126,200 Miles
Old Oct 14, 2002 | 06:37 PM
71swissaqua's Avatar
71swissaqua
Idle still too high
Is your timing way advanced? I've noticed on mine if I advance it sometimes I have to back down my curb idle.
Clint
Old Oct 14, 2002 | 07:22 PM
airharley's Avatar
airharley
Idle still too high
What kind of carb are you running? You could have the butterflys sticking open from the throttle return spring not having the correct amount of tension on it. Also look down the top of the carb and see how much gap you have in the butterflys. If you have more then 1/16 of an inch gap you are off of the idle cicuit and the air rushing by is sucking the fuel out as if it were driving down the road. Just don't check the butterflys while the engine is running.
Old Oct 14, 2002 | 07:30 PM
Bronco408w's Avatar
Bronco408w
Idle still too high
Old Oct 14, 2002 | 08:52 PM
WrenchHead84
My timing is at 6 degrees BTDC. As far as the return springs go, they are a suspect. I can put pressure on the throttle lever and force it down to maybe 800 rpm's. I'm going to try to get new springs soon. If that doesn't solve it....man oh man. I can check the butterflys, but when I had it pulled off, I checked that anyways. It appeared to be fine.
WrenchHead
Old Oct 14, 2002 | 10:53 PM
airharley's Avatar
airharley
Idle still too high
What you are looking for is the .025 wide groove that is cut into the bottom of the carb bores. If the grooves aren't visible with the throttle closed then you are past the "Idle Circuit" Look for a bent linkage rod or partically open secondaries. The secondaries shouldn't have any gap between the butterfly and the wall. I know a lot of stuff to look at closely. What may help is knowing exactly what carb you are running. ie... Holley, Edelbrok, Carter, FoMoCo, Demon, or Rochester QuadraJet and the cfm if you know it off hand.
Old Oct 15, 2002 | 10:56 AM
WrenchHead84
The carb I'm running is the stock motorcraft carb, but it was rebuilt by holley. I'm not sure what the cfm is on the stock carb.
WrenchHead
Old Oct 15, 2002 | 02:11 PM
Franklin2's Avatar
Franklin2
Idle still too high
Do you have vacuum on your dist at idle? This would make it idle fast too, although I guess you would have recognized this when you pulled the line to check the timing.
Incorrect or bad PCV valve?
Leaking brake booster? Block the line off to see if it slows.
Old Oct 15, 2002 | 07:25 PM
WrenchHead84
Found the Problem!!!!
I looked at a vacuum diagram...finally...and found an incorrect routing. The distributor was basically getting full vacuum right from the manifold, leaving it at full advance the whole time. I corrected the lines, and it now runs fine. As far as a vacuum leak goes, it would normally slow the idle...I believe.
WrenchHead
1979 F-150 Custom. 302 V-8 4-spd 2WD. 126,300 Miles
Old Oct 15, 2002 | 09:16 PM
fatfenders's Avatar
fatfenders
Idle still too high
Wrenchhead
Franklin is correct. Too high idle is very often caused by a vacuum leak. Glad you found your problem anyway.
'fenders
Homerunking2394
Jul 29, 2020 07:45 AM
plowboy12
Feb 12, 2014 09:50 PM
4caster
Aug 9, 2009 04:43 AM
PWKings
Aerostar
Mar 11, 2003 07:16 PM
WrenchHead84
Mar 10, 2003 08:35 AM
