Sponsored by: Auxito
Broken ignition linkage rod?
Old Dec 20, 2006 | 04:52 PM
dnamelton's Avatar
dnamelton
I have a 1997 Ford F150 with a 4.6. I went to start the truck this morning in freezing cold Colorado weather. I turned the key and it went to the run setting, but would not engage the starter. All the power was on to the truck, but the key would not turn off of the run setting or start the truck. I took everything apart and checked the ignition switch and the key cylinder drum, they seemed to be fine. I noticed that the plastic linkage between the cylinder drum and the ignition switch seems to be disconnected. Since this is inside the steering column, I do not know how to access it to repair it or if it even can be. Any help or suggestions--would be greatly appreciated.
Thank You
Old Dec 21, 2006 | 12:17 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Did you get it figured out yet?
You have to pretty much pull the whole columnn apart to replace the actuator rod.
If you're going to tackle it yourself might find it easier to remove the complete steering column to work on it.
Old Dec 21, 2006 | 12:50 PM
JH6's Avatar
JH6
I had an easier time just calling the junkyard, and getting a used steering column for 40 or so bucks, then swapping the entire thing in.
Just get one with the steering wheel, and swap your airbag onto it.
Real simple ordeal.
Old Dec 21, 2006 | 06:56 PM
dnamelton's Avatar
dnamelton
Thank you for your suggestions,i might try the junk yard idea.
Action410
Jan 18, 2013 07:40 PM
codymoch
Nov 17, 2011 07:51 AM
08gasurveyor
Nov 15, 2011 08:53 PM
Frozen_Joker
Sep 25, 2010 09:23 PM
89MustangGX
18
Mar 1, 2007 03:46 PM
