Tick/Click/Rattle ONLY when steering left??
Old Dec 20, 2006 | 09:25 AM
jtexfisher's Avatar
jtexfisher
I know that sounds nuts...but true.
My '05 SuperCrew suddenly developed a rattle/tick/click from the left of the steering column area ONLY when the wheel is turned to the left. Seems to be coming from the dash/knee area. At first I thought it was a loose panel, but I can't find a culprit. It's most noticable when running at highway speeds and doing little lane corrections. Straight or right it's as quiet as can be. Really is making me NUTS as otherwise it's a nice tight truck.
Anybody ever seen such in their 150??
Thanks!
jtex
Old Dec 20, 2006 | 10:09 AM
sysman_rick's Avatar
sysman_rick
Nothing strange like that. Do you off-road ?
Old Dec 20, 2006 | 10:23 AM
ford9c's Avatar
ford9c
You might want to check around the steering column under the dash. I remember a post regarding a clicking noise when turning the wheel and it turned out to be a white nylon collar on the steering column under the dash that would rub against something else under there when the wheel was turned. If you can get it to do it in the driveway you might be able to spot the culprit.
Old Dec 20, 2006 | 10:38 AM
jtexfisher's Avatar
jtexfisher
sysman_rick: Minor offroad use. Logging roads to hunting areas. But I haven't been offroad for a few weeks now.
ford9c: I'll try that later and see.
Thanks all!
Old Dec 20, 2006 | 11:06 AM
spiggy769's Avatar
spiggy769
Thanks!
jtex
Your not nuts...same exact thing happened to me and only while turning left...the dealer ended up replacing the Steering Shaft assembly ( Part # 5L3Z-3E751-A) while under warranty and everything is okay. Hope this helps.
Old Dec 20, 2006 | 04:06 PM
Red Rocker FX4's Avatar
Red Rocker FX4
I had the same thing on my truck and the dealer replaced the steering shaft and it still had a noise. They then replaced the bearing that the shaft goes through in the firewall and that was what finally fix my noise.
Old Dec 20, 2006 | 04:21 PM
jtexfisher's Avatar
jtexfisher
Yuck...mine is out of warranty and this sounds expen$ive.
Wonder if it's just irritating, or is something really broke on trucks with this symptom? Did the dealers make it sound like
'YOUR GONA DIE FOR SURE IF WE DON'T FIX THIS!!!!!'
or
'OH, Ooooooookaaay...we'll fix it if we HAAAAAAAVVVVVVVEEEEEEEE to. Gee Wally, there goes some more of OUR money just to keep some fool who thinks that for $20k it should WORK or something...eeesh.'
No opinons here about dealer service..nope, nada.
jt
Old Dec 20, 2006 | 06:28 PM
Red Rocker FX4
The dealer/mechanic never said it was a do or die problem. I only had 6K miles on my truck so I figured I might as well use my warranty.
ironheadchopper
Oct 28, 2011 12:56 PM
Black306
Sep 23, 2011 02:39 AM
JDW124
Jun 15, 2010 09:27 PM
bigblue80
2004 - 2008 F150
16
Feb 11, 2006 12:35 AM
scottspoerry
Apr 11, 2005 03:41 PM
