Intermittant running problem
Old Jan 16, 2007 | 07:50 AM
  #31
subford's Avatar
subford
Originally Posted by Old_Paint
If the truck ran really great with it disconnected (should have turned on the CEL)
Not true. But will return a code if you run the self test.
then you're running on a very rich mixture, which should make it stutter a little and rob power (my ECT croaked one time).
Not true, it would tell the EEC that the water temp is over 250 F and it would be running lean or use learned values.
Old Jan 16, 2007 | 08:40 PM
  #32
dracip's Avatar
dracip
Still haven't bought the new sensor and truck runs awsome with it disconnected - no stutter, easy starts etc - I almost hate to hook it up again - only negative symptom is CEL is on. Will check with advance on motorcraft part and advise on results. Thanks to all
Old Jan 16, 2007 | 09:33 PM
  #33
subford's Avatar
subford
Most of the members post that their CEL (MIL on Fords) say their light never comes on when they have a bad ECT sensor as the EEC does not know what the Temp of the engine is, maybe disconnected it will give one. Let us know if it goes out when you replace it.
Old Feb 4, 2007 | 04:47 PM
  #34
dracip's Avatar
dracip
I finally purchased a new ECT sensor and installed it. The check engine light now stays off and truck is running fine so far. The ECT I bought was from autozone and cost about $16.00. It appeared to be of much better quality than the one I took out. The new one is made in USA and is heavy brass and plastic. The faulty unit I took out was completely plastic and cheap looking. This truck forum is an awesome tool. I know if I took this to the dealer It would have cost hundreds more to fix.
Special Thanks to SUBFORD and everyone else who helped me on this.
ReForder
2004 - 2008 F150
40
Jan 2, 2012 12:36 AM
forq2
15
Jun 13, 2011 06:31 PM
Woodtroll
4 Cylinder Engines
May 3, 2007 08:49 AM
WeWonIt
Bronco II
Sep 9, 2003 11:27 AM
