overhead console.
Mar 26, 2007 | 11:08 PM
Willie,
Interested in the electrochromatic Mirror... this shows the compass and temp? How does this work?
Thanks,
AzSuperDuty
Quote:
Originally Posted by y2kfordparts
Well just heard from my bodyshop that a complete dash harness is needed for
the 2000-03 models because the trucks had to be ordered with the options on
the vehicle to make it work. For 2004-up the harness already in the truck should
have the conectors there that are needed to make it work. My customer had to
go with an electrochromatic mirror to get the compass and the temp settings.
Willie
www.fordpartsguy.com
Mar 27, 2007 | 09:32 AM
Yeah it shows both compass and outside temp.
It has a sensor the mounts on the back of it that monitors everything.
Shoot me your vin and I can get you a price.
Willie
Mar 27, 2007 | 11:06 AM
Willie,
I just sent you a PM.
Mar 27, 2007 | 09:30 PM
[QUOTE=y2kfordparts]Yeah it shows both compass and outside temp.
Willie
www.fordpartsguy.com[/QUOTE ]
Willie,
Surprisingly enough... we took delivery on the truck today... and looking through it I find I already have a compass (in the info center/ odometer) and the outside temp is provided in the climate control display so I am hooked up! I knew about the compass and for some reason was brain dead about the temp in the climate control (even tho the display etc. is nearly identical to my 2003 Mercury Marauder) LOL.
So I'll not be needing that fancy mirror.
On another note ... our 2003 F150 has adjustable pedals and I understand that is an option on the 2005 F250 tho ours doesn't have it. Is it possible to retrofit that into the truck?
Same question applies concerning heated seats?
Thanks..
Mar 28, 2007 | 09:36 AM
Anything is possible but the main thing is the wiring for the heated seats and
I would have to do some research on the adjustable pedals and the heated
seats. I will have to get back to you .
Willie
Mar 28, 2007 | 09:54 AM
I have a SD CC XLT and am also very interrested in adding this option. Need price and availability for a gray one.
Thanks,
FM
Mar 28, 2007 | 11:15 AM
Quote:
Thanks,
FM
Sure shoot me your vin and I will get a price on it for you.
Thank you
Willie
Mar 28, 2007 | 11:27 AM
Willie,
Wanted to check that you reveived my VIN number via the private message? Thanks,
Jeff
Mar 28, 2007 | 12:06 PM
Hey jeff
yes i have your vin and I am working on it. I had some questions on it so I am talking to my service tech and bodyshop on it.
Willie
05F250DSL
Oct 20, 2013 08:17 PM
imprezdcrew
Jan 25, 2013 05:08 AM
djdrexler
Aug 1, 2012 02:00 AM
EZFEED
1997 - 2003 F150
Jan 25, 2010 06:18 AM
