Dead Truck!!!
Old Dec 16, 2006 | 08:32 PM
erik-the-viking's Avatar
erik-the-viking
Dead Truck!!!
Emergency...
Truck just died at a major intersection... Maybe ran out of diesel but the digital readout offered 20 mile till empty. With that in mind, I just replaced 2 resisistors in the digital readout so I don't know if it is calibrated.
Does the 2001 F250 Lariat 7.3 diesel self prime or is there something I should knowafter adding diesel to tank via gas-can...
No indication that the truck was about to die...Just died on the way to gas station..
Any info wiil be gladly accepted...
Old Dec 16, 2006 | 08:37 PM
JOE-M's Avatar
JOE-M
I would put at least 10 gallons of fuel in it. next turn the key on and wait for the fuel pump to stop and turn it off. Do this 3 more times and crank it on the last one. It should start up. It may run a little rough for a few miles until the air gets out.
Good luck, Joe
Old Dec 16, 2006 | 08:39 PM
Uzumati's Avatar
Uzumati
Describe your die - did it sputter and die like running out of fuel or was it a sudden cuttoff like the CPS going out?
Old Dec 16, 2006 | 08:42 PM
erik-the-viking
Spluttered and coughed to a death like a smoker in a crowded bar... No warnings...
Old Dec 16, 2006 | 08:48 PM
DirtRacinStroker's Avatar
DirtRacinStroker
I've experienced that a few times........readout says 20 miles left.....not!!! Just add 5+ gallon of fuel, let the pump run 3 or 4 times.... it'll start, run rough for a bit but it'll clear up.
Old Dec 16, 2006 | 08:53 PM
Uzumati's Avatar
Uzumati
I love the description.
You shouldnt have to prime it the pump should suck it right up. Some people do fill the fuel bowl with fuel so the injectors arent dry. Like joe sadi cycle the key a couple of times and you should be fine.
Old Dec 16, 2006 | 08:56 PM
erik-the-viking
Thanks for the info guys. Got a full trailer for work tomorrow and didn't know what to do. Just paid dealer $1500.00 last month for sensors and switches so my heart went "pitt-a-Patter" so near to Christmas.
May I add that I added 3 gallons of diesel to the tank after the incident and still wouldn't start. Must I add more fuel to the tank? What do you think???
Old Dec 16, 2006 | 08:58 PM
JOE-M's Avatar
JOE-M
I'd add more fuel, but you still need to cycle the key a few times to get fuel up to the injectors. If you don't it'll just crank and crank and still not start up.
Joe
Old Dec 17, 2006 | 07:43 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Screw the digitall dumba$$ readout. What did the fuel gauge say? Yeah it should self prime but that is via a lifting pump. If you ran out of fuel, I would recommend unscrewing the cap of the filter bowl and filling it with diesel. Wait a few minutes, have a cigarette , etc, then see if you need to put more in. If it is full when you first look, or the fuel level does not go down, put cap back on and try. If there is no hum from the pump under the driver seat, fuel pump may be dead or no voltage there. Need to track that down then.
Edit, if you suspect the fuel pump is not running, hit it with a rubber mallet and see if that gets her going. If that works, the pumps life is limited and I suspect it will happen again.
Old Dec 17, 2006 | 10:40 AM
Kwikkordead's Avatar
Kwikkordead
One thing to remember about electric fuel pumps. They rely on the fuel that they are pumping for lubrication. You run out of fuel and it's the same effect as running your engine out of oil.
For that reason alone I never, ever, ever, (did I say never? ) run below 1/4 tank on any vehicle.
Old Dec 17, 2006 | 03:45 PM
sandlapper's Avatar
sandlapper
Red face
When you get it started after running it dry you will never, ever, never do it again when you see how rough it is on the engine.
I have done it once. That's all it took. Like Kwik, when the light comes on start looking.
Old Dec 18, 2006 | 06:35 PM
erik-the-viking
Tried everything you said but still No Start. Eventually batteries died after several hours of cranking. Brought it to Ford dealer this morning to have codes pulled.
They gave me a grocery list of problems but could only pull one code; a CMP code/P0340.
1) Fuel pump burned out
2) Replace Fuel pressure regulator
3) Replace fuel drain
4) Bad CMP sensor (just had that replaced in October)
5) Replace fuel filter and lid.
Needless to say, I felt violated after receiving the grocery list of problems, especially since I just paid over$1500.00 in October to have several sensors and switches replaced. The current estimate for the above grocery list was almost $1300.00 before tax and that wasn't including the CMP sensor.
I opted out of the transaction and made plans to have the truck towed to my property for further inspection. I know the defective fuel pump would ultimately stop the truck in its tracks but can't say if the pump went faulty after trying to crank the engine with no diesel in the lines.
Any thoughts?
Old Dec 18, 2006 | 07:26 PM
pullinair's Avatar
pullinair
The likey hood of all of the above needing replaced is non sense.
1) a.) i would only say that the pump is burnt if you cant hear it running anymore when cycling the key. Geta friend or a significant other in there to crank and go under the truck and put your hand against the pump , feel if its workin.
b.) Your inlet side of the pump may be clogged at the screen no along any fuel to enter the pump due to running the tank so low. in other words you picked up a lot of crap at the bottom of the tank. You can remove the pump and tuen it upside down and slighltly tap it against a work bench to unclog it.
2) I dont have any experience with the FPR so another member can post about that.
3)Maybe, i say maybe the cmp but it usualy restarts then dies 2 miles again down the road, Im not rulling it out but it usualy dies hard with a cmp, not cough.
4)Fuel drain? If yours isnt leaking (Fuel in the valley of the engine) and it drains the fuel when you open your valve, and stops draining when you shut it youre good to go!
5)I would definately replace your filter after running that low on fuel. Even if fuel isnt your issue. Fuel filter lid? They are smoking you know what. The oem style lids seal the best and rarely need to be replaced. I can only imagine replacing one if you strip out your threads on the lid. That hardly ever happens.
sounds to me like they were getting ready to throw some serious parts at it!. Did they give you a readout on the codes with the estimate? If so you need to post them. If they didnt i assume you paid a fee for the diagnostic/evluation of the repair. Go back and get the codes they pulled. I hope this helps. Still need more info on the staus of fuel pump....running or not and codes.
Tim
on edit: i just saw that they pulled a code for the cmp(CPS), did you replace it yourself yet? everything else above still applys.
draboo
Nov 22, 2011 02:35 PM
BrianFX4
2004 - 2008 F150
Jul 10, 2008 09:21 PM
Beachbumcook
May 29, 2004 04:53 PM
Drawsoncad420
Dec 7, 2002 07:49 AM
