Sponsored by: Auxito
Cam position sensor
Old Dec 15, 2006 | 12:23 PM
Therickster's Avatar
Therickster
Cam position sensor
my check engine light came on and i got a buddy to get the code from it and it was the cam position sensor i bought it but dont know where to start or find the location of the old sensor. what needs to be removed to put it on and do i need any special tools?
Old Dec 15, 2006 | 07:57 PM
Johnny Langton's Avatar
Johnny Langton
It's on the driver's side of the engine,mounted on the front timing cover.
If it's a '97-'98 4.6L,it'll be behind the coil pack bracket,if it's a later 4.6L or 5.4L with COPs,it'll be right on the front of the engine in the same spot-it's got an 8mm or 10mm head bolt that holds it to the cover.Super simple to change.
JL
Old Dec 16, 2006 | 12:58 AM
Racerguy's Avatar
Racerguy
Welcome to the forum Ricky
What size engine in your truck?
JL has the answer if it's a V-8. If it's a V-6 then it's different.
Old Dec 16, 2006 | 07:39 AM
Johnny Langton
Very true..I forget about the little 4.2L being in the trucks.
JL
Old Dec 16, 2006 | 09:52 AM
Racerguy's Avatar
Racerguy
I've seen a lot more cam position sensor problems on the V6 which is why I asked.
Actually I don't recall ever seeing a problem with one on a V8.
Mind you it's early in the morning here and my brain may not be working quite right yet
Old Dec 18, 2006 | 07:17 AM
Therickster
its a 99 little V6. i checked it out and it looks like there is some hoses i need to remove to get to it, so i will probly have to get a seal or two but i think i found it.
Old Dec 18, 2006 | 10:09 AM
Racerguy's Avatar
Racerguy
I seem to recall that on the V-6 they are a bit of a pain to access but not too bad. If I remember right you have to remove the heater hose tube from the top of the water pump.
After that there's just one electrical connector and 2 screws that hold it on.
Fury
Dec 14, 2023 09:49 AM
bcaughhorn
1997 - 2003 F150
Jul 20, 2013 02:46 AM
Roasted7
Feb 3, 2013 08:07 PM
fox3698
1983 - 2012 Ranger & B-Series
Jan 5, 2013 07:21 PM
Matts72
General Automotive Discussion
Dec 6, 2007 12:55 AM
