cam shaft position sensor question
Old Jan 5, 2013 | 04:16 PM
fox3698's Avatar
fox3698
2000 flex fuel 3.0 4x4 .
i have checked the fuel pressure and it is good.
i have good stong spark to each plug.
i have cleaned each plug. and i have a no start situation.
does the cam position sensor control the injectors firing?
or does it control the firing order for spark?
i can crank her for a few cycles .
and then pull the plugs and they are dry,with no fuel smell.
the motor has a cam position sensor and a crank position sensor.
i just need to know what each one controls.
Old Jan 5, 2013 | 04:31 PM
brbleaujr's Avatar
brbleaujr
If you have spark, your crank sensor is ok.Cam sensor opens injectors at the correct time.I am have the same problem with a 2004 4.2L.I am at a loss myself.If I find any info I will relay it to you.
Old Jan 5, 2013 | 04:53 PM
wp120470's Avatar
wp120470
You nees to check for fuel pulse at the injector. See if they are getting pulse from the computer or not. It can be checked with a test light if you are careful with lead conected to each pin have someone turn the key over and see if the light flashes. if not you have a cam sensor bad or an ecu problem possibly. If it is the sensor, usually it will go into limp mode. This will keep the truck running on a low power range to get it to a safe place or garage. Check for the fuel pulse next and lets us know the results. Good luck.
Old Jan 5, 2013 | 04:55 PM
brbleaujr's Avatar
brbleaujr
I just figured out my problem.My son dropped his keys.For the heck with it I tried the spare key.Truck started right up.The chip in the key must have bean damaged.Did you drop your key,worth a shot.Let me know.
Old Jan 5, 2013 | 07:21 PM
fox3698's Avatar
fox3698
Thumbs up
well i got her running!!!!!!!!!!!!!!
thank-you for your insight everyone.
i went out and reconnected the battery.
pulled the connection at a injector port.
tested it for a constant ground without the ignition on. ( it does have)
and had my wife crank it over so i could test the injector lead.
and by god she fired up and died.
after three start=ups i reconnected the hose to the air cleaner and intake.
hooked pvc and iac back and she ran a little rough, then cleared up.
while i was checking for fuel pressure friday i had changed the fuel filter.
it had bad gas in it,and i poured it into a cup.
the fuel from the tank was clean, so i installed the new filter.
i bleed the rail till it had clean smelling fuel.
i also pulled the plugs and left them out untill today.
i tried to start her a few hours ago and nothing.
we went to test the injectors and she runs .
maybe i reset something by pulling the lead to the injector.
it must have been the bad fuel the whole time.
maybe a few hours ago when i tried to start it i had finished bleeding the bad fuel from the rail.
there is not a engine light on, after driving for a few miles .
ever since i had bought it she had a slight stumble at idle.
now that it gone too.
thank-you everone for the info and have a great night.
clodmore
3.0L V6
226
Jan 25, 2019 07:01 PM
Moore558
3.8 & 4.2L V6
Mar 29, 2012 09:44 PM
1fast4.6
Modular V8 (4.6L, 5.4L)
Mar 16, 2011 06:30 PM
dirtmonkey11
Sep 10, 2010 10:25 AM
dangrv
Modular V10 (6.8l)
16
Sep 1, 2009 12:58 PM
