351m turbo
Old Dec 13, 2006 | 04:11 PM
captain p4's Avatar
captain p4
351m turbo
ok, wasn't sure if I should put this here or the forced induction forum, move if need be..
I searched this forum and came up with very little.. there was a couple of posts in the other forum, but not much really.
Has anyone done a turbo setup with a 351m? With their low compression it seems like they could be a good candidate for forced induction. How about the internals, do you think they would hold up to a moderate amount of boost? say .. 7-8psi? What do you think about those STS universal remote mount systems..? it seems like this would be a good application for one of those kits.
Not really sure what I want to do with this slug of an engine at this point, just kicking ideas around, so lemme know what you think.
Old Dec 13, 2006 | 04:40 PM
grclark351's Avatar
grclark351
"Watch the Matt and Buzz install a towing package on an STS Turbocharged 5.3L Chevy Pickup and crank up the horsepower and torque on Truck Universe coming December 9th and 15th at 10:30am EST on SPEED Channel." http://www.ststurbo.com/universal_system
that's an excellent idea, lots of room under a truck. you'l need a boost referencing ignition retard system and/or knock sensor though, and run pump premium for sure.
http://www.supermotors.net/getfile/4...size/boost.jpg
Old Dec 14, 2006 | 03:52 AM
mike240zt's Avatar
mike240zt
have thought the idea myself but haven't put any effort into being serious about it. stock compression would be about right for turbo applications as far as getting more boost. i'm not a total expert but i think without upgrading to heads with a better quench area you'd be very prone to detonation. even at 6-7 psi.
Old Dec 14, 2006 | 11:16 AM
captain p4's Avatar
captain p4
I wonder how well the STS would perform offroading.. i wonder if getting it caked with mud would be an issue.
Old Dec 14, 2006 | 05:10 PM
mike240zt's Avatar
mike240zt
I'm sure if installed properly the STS would perfprm just fine however air cleaner location kinda sucks. the underside of my truck gets painted with mud when i play. could pipe it to the engine bay but i think that would make the turbo less efficient. A decent rebuild with higher compression/cam/headers/4 barrel intake and carb would be the most practical. I like turbo's however IMHO don't think they go well in a 4x4 unless you're buildn a mud dragster. compensating and overcompensating for turbo lag in some 4 wheeling situations would potentially screw ya. On a side note if your idea of 4 wheelin is foot to the floor non stop action then do turbo lol.
Old Dec 15, 2006 | 05:15 PM
bigperm2's Avatar
bigperm2
I also doubt the low compression pistons are forged. If I were building a turbo motor, I would definitly want forged pistons. Maybe Tims Hyper pistons made for Aussie heads, but used with open chamber 351M heads would work well, but still with low boost.
Old Dec 15, 2006 | 05:29 PM
packlet's Avatar
packlet
wth?
http://cgi.ebay.com/ebaymotors/ws/eB...m=250059370089
Old Dec 15, 2006 | 09:31 PM
captain p4's Avatar
captain p4
I almost want to ****** that up because its so cheap and probably pretty rare even if I don't have any real plans for a turbo at this point.
Old Dec 15, 2006 | 10:02 PM
packlet's Avatar
packlet
wouldn't you need two of them? or could one run a single turbo off one bank?
oh, i get it!
you run the exhaust from the passenger side into the other port on this thing on the driver's side. pretty slick. ok, now how to blow thru the carb...
Old Dec 15, 2006 | 10:12 PM
captain p4's Avatar
captain p4
I'm almost positive thats how single turbo setups work.. maybe i'm wrong though. I bid up to 85, but whoever else bid on it must've set his max bid up there pretty high. I don't want it that bad.
Old Dec 15, 2006 | 11:05 PM
packlet's Avatar
packlet
oh, and that ak miller thing is designed for a propane turbo application, where compression is your friend and detonation is easier to avoid...
Old Dec 15, 2006 | 11:10 PM
captain p4's Avatar
captain p4
thanks for mentioning that after i bid on it.. haha, oh well. I didn't bid high enough anyway.
lil-red-f150
13
Mar 30, 2015 01:33 AM
quincyj34
Feb 28, 2014 07:51 PM
BlueOvalBud
13
Dec 26, 2010 05:47 PM
Big_Red_1993_F250
Jul 31, 2006 12:53 PM
ChronGen
May 27, 2005 08:13 PM
