Edelbrock 1406 question
Old Dec 13, 2006 | 02:34 PM
jowilker's Avatar
jowilker
I have just returned an Edelbrock 1406 to my truck. Does the dist. vac. advance tube connect to the passenger side or drivers side vac. port on the carb? I have no idea where the papers that came with it are now.
thanks
John
Old Dec 13, 2006 | 06:05 PM
lance65's Avatar
lance65
John it goes on the passenger side
Old Dec 14, 2006 | 06:01 AM
jowilker's Avatar
jowilker
Thanks, I guess I will have to just on it a little, it doesn't want to take gas off idle, an I aint much of a carb man.
John
Old Dec 14, 2006 | 06:15 AM
ddavidv's Avatar
ddavidv
I just picked one up at a swap meet for mine last month. Any tidbits I need to know on installing it? I'm still cleaning up the intake for mine.
Old Dec 14, 2006 | 06:26 AM
jowilker's Avatar
jowilker
They are made for manual shift, if you have an automatic, you will need to buy their kit to make it work.
John
Old Dec 14, 2006 | 06:56 AM
darrin1999's Avatar
darrin1999
i dont know about an fe intake but on my 460 i had to use a 1/2" spacer for the linkage to clear
Old Dec 14, 2006 | 09:52 AM
FordBoypete's Avatar
FordBoypete
John,
Is your accelerator pump working after that 4V sat dry & unused for a while?
FBp
Old Dec 14, 2006 | 07:12 PM
jowilker's Avatar
jowilker
What is the best method to check the pump?
John
Old Dec 14, 2006 | 07:24 PM
banjopicker66's Avatar
banjopicker66
Symptoms of a bad acclerator pump: usually the truck will gag when you goose it to move off from a stop.
You may want to do this check with the engine cold, to avoid burning yourself. If it sits until it gets cold, gas may percolate out of the carb, and give a false reading in the next step. Hence, run it for a few seconds, just enough to get the carb filled with gas.
You will also need to have the choke open. If it is electric, run it for a bit longer, then shut the eninge down. Turn the ignition back on, and let the electric element heat the choke open.
Check it like this: Run the engine for a few seconds, to make sure the carb is full of gas.
With the engine off, remove the air cleaner and look down into the throat of the carb.
While looking down, goose the acclerator linkage several times, all the way to full throtte.
If the accelerator pump is good, you will see two streams of gas squirt down into the carb.
If it bad or poor, you may see only drops or droplets, or nothing at all.
Old Dec 20, 2006 | 10:54 AM
jowilker's Avatar
jowilker
Went out to drive the truck yesterday got 1/2 block and ran out of gas.
I hadn't done any adjusting and it worked better when it got up to operating temp, but didn't want to take off from idle. This morning I couldn't get it to crank early on. I moved the linkage on the A pump from the end to the third hole. It takes off better but sitting at a traffic light it will load up and not want to take off. The last time at the light I put it in neutral and it idled much better.
Hopefully I will get the hose off from the carb and check out the fuel flow from the pump.
John
Old Dec 20, 2006 | 11:54 AM
lance65's Avatar
lance65
put your hand over the airhorn while the truck is running.If it revs higher then you have a vacuum leak,if it bogs down then it may be too rich.Also check that your vac advance is working.spray starting fluid around the base of the carb and linkage to check for external leaks.Are you getting a "GOOD" squirt of fuel from the carb down the ventuis?You may have a baad accelerator pump.
Speedjester
Ford Truck Parts for Sale
Dec 12, 2014 11:35 AM
oft
Oct 31, 2014 02:03 AM
PRIMERED79 SHORT BED
17
Oct 20, 2013 06:27 PM
Dave2488
Jul 28, 2012 07:07 AM
loudfords
Nov 15, 2002 02:20 AM
