Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Oddball sockets...
Old Dec 12, 2006 | 07:36 PM
eco's Avatar
eco
Oddball sockets...
I am trying to find a 1/4 inch drive 1-1/8 in. socket, but nobody seems to offer one.
What would be the best way to come up with something like this?
Old Dec 12, 2006 | 08:02 PM
GLR's Avatar
GLR
1/4f to 3/8 m, 3/8f to 1/2 m adapters couldn't find "matco" listing of 1 1/8 socket in 3/8 drive. They are not made in 1/4" drive due to overloading the ratchet or breaker bar.
Old Dec 12, 2006 | 09:14 PM
jbullfrog's Avatar
jbullfrog
Question Why?
Seems like underkill, but if you insist. I would suggest the flat size adapters. They come in a set of 3 and are the thickness of the old spinner wheels.
Old Dec 12, 2006 | 09:21 PM
Racerguy's Avatar
Racerguy
Ok I have to ask....what are you doing that need that socket?
Old Dec 12, 2006 | 10:00 PM
Ford_Six's Avatar
Ford_Six
I'm guessing checking drag on a diff.
Just use an adaptor.
Old Dec 12, 2006 | 11:08 PM
eco's Avatar
eco
Yes, preload on a diff...rolling torque. I don't like the adaptors because of the accumulated slack. My in. lb. torque wrench is 1/4 in drive and the nut is 1-1/8 in.
If I can come up with the socket that would be great! There has to be a way...
Old Dec 12, 2006 | 11:55 PM
fixnair's Avatar
fixnair
Got Welder?
Old Dec 13, 2006 | 12:42 AM
eco's Avatar
eco
I take it you are suggesting that I weld a 1/4 in. socket to the back of the 1-1/8 socket...hmmmm...did not think of that one.
And no I don't have a welder, but I can easily find someone that does. If I can't come up with a socket - which I probably wont - this will be my plan b.
Thanks for the idea!!
The only hard part about this will be getting the 1/4 in. socket perfectly centered on the bigger socket...
Old Dec 13, 2006 | 01:10 AM
96ExtracabPSD's Avatar
96ExtracabPSD
The slack from the adapters won't affect the torque readings.
Old Dec 13, 2006 | 02:41 AM
eco's Avatar
eco
True...
But it's a pain to deal with and if I can get around it I will.
Old Dec 13, 2006 | 03:25 AM
Torque1st's Avatar
Torque1st
Posting Legend
Just weld adapters in instead of a socket. Still, I have not had any difficulty dealing with the slack in the adapters. For the amount of torque applied in this case you could even JB Weld the adapters.
I have designed and programmed torque testing machines for tool manufacturers and the slack just required some movement programming but did not change the readings. Of course I was dealing with high $$$ NBS certified torque measurement equipment.
blackjack2_1
Jan 3, 2015 02:20 PM
macguy
6.7L Power Stroke Diesel
Jun 29, 2012 09:26 AM
regidog
Mar 20, 2011 08:32 AM
midlf
Aug 15, 2008 02:20 PM
Jim_Banville
Jul 16, 2002 05:58 PM
