never ending problems... fuel now
Old Dec 12, 2006 | 04:29 PM
KRAZY KRAMER's Avatar
KRAZY KRAMER
Cool never ending problems... fuel now
i have had so many problems with this truck... its been down for about 8 1/2 months now... some one please help.. a while back the truck started studdering and jumping with absolutley noooo power... ran like a bad fuel filter.. replaced it ran okay for about a day but still not the best...replaced the fuel pump with kwick's vw adaption and ran okay for a couple days...i just tore some stuff off the engine to tap into the fuel rail on the passenger side head to get a pressure reading.. there was a lot of air in there figured this might be my problem .. air lock in the system because it is running like air or a plugged filter... read the pressure it was up around 70 with truck not running but key on to power pump.... what should the pressure be????... and when the pump shut off the pressure blead off... should that happen?? or is there a bad check valve??.......im praying for a mirracle
Old Dec 12, 2006 | 04:39 PM
Pocket's Avatar
Pocket
Pressure should read close to the same at idle as it does with KOEO. So if it's reading 70 before you crank, and close to that with the engine running, then everything is fine. When you shut the engine off, yes you will lose pressure and it's normal.
Also, air at the end of the rail is normal. That is why there are regulated return kits available to upgrade the fuel system and get rid of that problem. It's a bad design from Ford, but shouldn't be the cause of your problem.
Are you still having the same studdering problems? Did you check for any stored codes in the PCM?
Old Dec 12, 2006 | 04:47 PM
KRAZY KRAMER
what does KOEO mean? and i thought i remember hearing the pressure being around 20-25...and i thought mine sounded high... will being that high in the rail effect anything? and the last time i had it out was was studdering and falling on its face... i havent checked for codes yet but im sure i have tons in there by the way its running... im ordering the pc based model from ae tonight!! thanks for the help and hopefully future help.. i need to get this thing straight
Old Dec 12, 2006 | 04:56 PM
bobnoxious's Avatar
bobnoxious
KOEO...Key On, Engine Off
Old Dec 12, 2006 | 05:04 PM
KRAZY KRAMER
thanks... im not too familiar with all the abbreviations on here...and there is a ton.. i saw a page a while back that had all them translated..but i cant find it now.. anyone know where this is?? thanks
Old Dec 12, 2006 | 05:26 PM
ponch37300's Avatar
ponch37300
go to the top of the page and you will see the common mods sticky they put back. One of the first posts has all the acranyms in it.
Old Dec 12, 2006 | 06:26 PM
Pocket's Avatar
Pocket
Your truck would barely run if fuel pressure was 20-25. Most trucks come from Ford set around 48-54 psi. There are some that come higher. International runs these engines at 70-75. The higher pressures give you better throttle response, and a quiet idle.
Get your diagnostic tool and pull the codes, then you'll be able to troubleshoot better. Right now you are kinda shooting at the hip.
Old Dec 12, 2006 | 06:38 PM
Kwikkordead's Avatar
Kwikkordead
In addition to what Pocket is saying about the codes, the air in the fuel rails needs to go. Have you done the Hutch mod and gotten rid of the quick connects?
Old Dec 12, 2006 | 07:01 PM
KRAZY KRAMER
i know i desperatley need to read the codes.. i just called ae and rush ordered one it cost a little more with the rush but i have to get it done... and i didnt look into the hutch mod yet but i did your vw fuel pump switch... which reminds me i figured out a slightly different way to adapt the outlet over on it to get it back to the ford fitting since there was an odd thread adaption
Tugly
166
Aug 6, 2015 12:46 PM
justenuf2b
48
Dec 5, 2013 10:45 PM
cbr600rx7
47
Jan 30, 2013 05:48 PM
CALINLEIR
Apr 28, 2009 01:47 PM
KRAZY KRAMER
Apr 17, 2006 02:26 PM
