New Guy
Old Dec 12, 2006 | 09:48 AM
skidsteersteve's Avatar
skidsteersteve
New Guy
I've check out this site a few time in the past and gotten some good info on my truck. I thought I'd list a few things I was curious about and see what I can find.
96 regular cab Ranger, one owner, 180,000 miles, 3.0/5sp, 2WD. Had one clutch at 100K (trailers are killers!), starter, alt, cam sensor/shaft, rear main seal, u-joints....I think that's all.
I'm about ready to put a clutch in and had a couple of trans question, too. Over the past few weeks, it has started getting really stiff to put it in 1-3. It's not grinding, like the sycros were going. It just won't go into those gears without a fight sometimes. I'm also looking at putting in a locker rear diff, any suggestions? (not ltd slip, but either air or electric lock, I get in and out of some construction sites and I need a 4WD, but don't have the $ to upgrade and thought a locker would be a decent compromise for now).
In a way I wish this truck would die so I could justify a new one, but it gets worked hard almost every day and just won't give up, so I figure I can spend a couple bucks on her!!
Thanks in advance
Steve
Old Dec 12, 2006 | 05:27 PM
rubydist's Avatar
rubydist
How long has it been since you changed the trans oil? It will probably shift a lot better if you put new oil in, if its been a while. I changed mine at 70k and it made a suprizing difference.
Old Dec 12, 2006 | 09:52 PM
fordboy_52's Avatar
fordboy_52
Welcome to FTE Skidsteersteve! Im glad you chose the best site on the net for Ford-Trucks!
I beleive that its time for your syncro's to be tired and prolly need to be changed. they have outlived their expected life!
see you around the boards
Matt
Old Dec 12, 2006 | 10:40 PM
skidsteersteve
I'll try the oil change. It has been a while since I changed it last(say 80K). Probably the reason the sycros have lasted so long is because I drive it like a non-sycro tranny. Too many years running 9,10, and 13sp in trucks. I usually let the input shaft slow down a bit before cramming it into a higher gear and have been known to double clutch on the downshifts. I wanted to give it all the life I could. SSS
natewoz
Offroad & 4x4
Dec 30, 2015 08:05 AM
trailrider121
51
Feb 20, 2012 04:22 PM
bridqer
Mar 6, 2010 11:47 PM
BootHill
1978 - 1996 Big Bronco
Jan 18, 2005 09:30 AM
jroehl
May 1, 2004 01:33 PM
