Rear end suggestions?
<!Ok, now that I've got my old F150 almost squared away (see sig) to be sold>, I'm going to be looking at doing some rear end work on my F250 (see sig).
The axle code on the doorpost is 35. The paperwork I got with the truck (bought a few months ago) says that it had 4.10 gears installed (at the dealer, I assume) when it was bought new. Coupled with the 351 @ 120k miles, I'm not liking the mileage--10 to 11 mpg. I do like the "getup and go" it's got right now, but I'm not a kid anymore, and don't really need it. Nor do I do alot of towing (but I may occasionally pull 5000 lbs or so, maybe 1-2x a year). So I'm thinking of putting in 3.55's or 3.73's. Any thoughts/ideas/suggestions? What kind of mileage increase would/should I see with this change for the 2 different ratios?
Also, I'm a contractor, so I occasionally have to pull into sloppy jobsites, and, this truck is a 1wd (why can't manufacturers just be honest about this?). Heck I got stuck on level damp grass with this thing (my own, arrrrghh). I'm fairly certain it's only an open differential, and I'm thinking that a locker would be the way to go over LS. I'm not looking to spend big bucks here, but for the ring, pinion and locker, I would say I could do about $600-$700 if necessary, installed myself. Which locker? What about expected ride quality? It's a 3/4 ton truck, so the ride is already harsh, which I don't mind in a truck, but I don't want something that's going to throw my rear end around in a turn or on an icy/snowy road. I like the idea of a manual locker, but I can't say I've seen anything reasonably priced along those lines, but would consider one if the price was right.
Thanks in advance for your help!
Jason
BTW, I would put new tires on with better traction, but the tires were brand-new (M+S street tires--don't recall brand)when I bought the truck 5 months ago, so I'll just wait on that. Even though my 150 has an open diff, the only time I got it stuck was when I took it sledding through some deep snow (she floated on the snow on my spare). I always kept good traction tires on the rear.
Jason
Thanks,
Jason
Anyways, to get to the person posting the question... Jason, I know what you mean about the disappointment of having an open diff, my old Chevy 2wd dually was a peg leg and so was my F350 when I first got it. They both sucked in mud and sand, even the F350, which is 4wd. The LockRight definately made a big difference in the off road ability of the truck. It claws it's way through just about anything now when in 4wd and there are places that I go now in 2wd that used to require locking in the front hubs. The $325 I spent for the differential was well worth it.
As for the ratio change, here is my experience in changing the ratio on a truck somewhat similar to yours. I'm running 4.56 gears and 33" tires (~4.30 effective ratio) without overdrive (C6 trans), and yeah, I am spinning a few rpms at freeway speeds. With your 4.10 axle, stock tires and E4OD overdrive trans, you're not really spinning all that high rpms, by comparison. Anyways, I noticed an increase in gas mileage going from 3.55's to 4.56's because my truck is heavy (F350 Crew Cab 4x4) and my engine is small (351), so it was really working hard to get the heavy truck moving. The lower (numerically higher) gears took some of the stress off the engine and I don't spend as much time with my foot deep in the pedal as I used to, which saves gas. The only area where I lost mileage was when driving fast on the freeway unloaded, because I don't have overdrive. Mileage and power when driving in hilly areas or when loaded, and both, was better with the 4.56's. I'm happy with this combination, except for not having overdrive. A .78:1 overdrive ratio would put me right about 3.55 final gearing (3.35 effective, with tire size difference), which would be right where I was before I did the gear change, for freeway driving, which that truck was great for, as long as there were no hills to climb. With your 4.10 gears and overdrive, you're right about 3.20 final gearing, which should be plenty high for the freeway.
Since your truck is also on the heavy side, but not as heavy as mine, and your engine is also small and you do have overdrive, I doubt you will be saving much gas by going with the 3.55's unless you do alot of fast driving unloaded on the freeway or live in a relatively flat part of the country. I don't know that the small gas savings would justify the cost of doing the gear change. If it were me, and I was dead set on changing the gears, I would change them to 3.73, which is a nice balance between power and mileage, if running stock size tires. Of course I'm not sure it's really worth it to spend the money for such a small change...
One alternative to changing the gears, is to change to a slightly larger tire size. If you were to put 33" tires on the truck (285/75-16, I think is what is in metric), assuming your stock size is 235/85-16 (~31.5"), it would be similar to having ~3.90 gearing instead of 4.10 and would be cheaper than doing a gear change, if you wait untill you need to buy new tires anyways. That will lower your rpms a little and you will still have good power as well. I ran that combination on a truck I had and it worked good.
Anyways, hope that helps ya out some, or maybe just adds more confusion to the equation LOL. At least it's one more thing to mull over anways...
Someone on another site calls this section of the midwest, "the foothills of Mount Level"
I doubt I'll be doing much roadtripping, either, so this truck would stay on the flat mostly.Jason
There are tons of threads on locker vs limited slip....the search function comes in handy for that and I bet you can find a few if you look through the last 5-6 pages of this forum.
As for as lockers go. I would not go with a locker for 2wd and mostly street use. They have characteristics that are best described as less than friendly for street useage ie...The spinning of the inner tire( you will see increased tire wear), the slack between deaccel and acceleration, a yank under hard throttle in a turn, and a locker could definiatly get you in trouble on ice. I would stick with a limited slip, it should help out alot for your truck and muddy conditions.
v
