460 engine problems
Old Dec 12, 2006 | 03:19 AM
rural_rob's Avatar
rural_rob
460 engine problems
Hi all, got a problem that I hope someone can help me with...
I have an F-350 with a 460 big block carby on LPG and petrol. I have taken it to a few mechanincs as it has been losing power, but they can't pinpoint the problem. They say pot 8 isn't firing, plus pots 3 & 5 are erratic (no difference running hot or cold). I have changed the plugs, plug leads, dizzy and coil, but still no change in the problem.
Possible faults suggested by various mechanics could be... lazy valve spring (one mechaninc thinks this is not the case though) or a valley gasket fractured between 2 cyls, or valve stem guide, or broken cam lobe. Temp running normal, so broken head gasket unlikely. There is no difference in running it on LPG or petrol
Symptoms are as follows:
- Left bank running significantly hotter than right bank
- Significant loss of power
- Running very rough
- Very rich exhaust
Without taking the valley and heads off, does anyone have any ideas of what the problem could be and ways to confirm or exlude these.
Thanks...
Old Dec 12, 2006 | 05:01 AM
scottie2hottie's Avatar
scottie2hottie
How many miles on the engine?
Old Dec 12, 2006 | 05:14 AM
viper1_2001's Avatar
viper1_2001
could be cam related, maybey worn lobes
Old Dec 12, 2006 | 05:19 AM
scottie2hottie
or worn[dead] hydraulic lifters...
Old Dec 12, 2006 | 09:10 PM
Piffery1's Avatar
Piffery1
Do a compression check and see what the readings are If some are low, squirt a litte oil in the low cylinders and recheck compression. If oil increases readings-suspect rings, if not valve, piston or gasket problem.
Old Dec 12, 2006 | 10:09 PM
Mil1ion's Avatar
Mil1ion
Because 7 & 8 adjacent cylinders and with the firing order, this is a known problem with worn out cylinder parts and also a nother reason to seperate the plugs wires on the valve cover..so they don't cross fire.
do a compression test on each cylinder 7 & 8 with the adjacent spark plug in ....and than then ...out.
Old Dec 15, 2006 | 06:23 PM
rural_rob's Avatar
rural_rob
Thanks all for your replies.
Motor was rebuilt about 100,000 kms ago (so 62,000 miles)
Have done compression tests... all 160-170. Did the crossfire with 7 and 8 and still could not get 8 to fire and 7 not to fire.
A new development just come up is that it has read high temps a couple of times in the last few days... Don't know if this is a wiring problem will all the buggerising around that has been going on under the hood, or if it is really overheating.
I will open her up over Christmas and see how it goes.
Old Dec 15, 2006 | 09:19 PM
77SilverStreak's Avatar
77SilverStreak
Does this motor have an EGR? If so, check the gasket between the EGR plate and the carburator. I had this blow out before, and it pumps exhaust into the intake, causing the motor to run like crap. If you want to check for an intake leak, spray either at the point where the intake meets the heads. If the engine speeds up, then its got a leak at that location.
Old Aug 17, 2007 | 02:46 PM
srennie's Avatar
srennie
why does my 460 pop and backfire when trying to start
Old Aug 17, 2007 | 08:42 PM
scottie2hottie
out of time? Might get more responses posting this in your own thread
Old Aug 18, 2007 | 02:18 PM
Piffery1's Avatar
Piffery1
I'd pull the valve covers an see if the valves on the cylinder(s) that are not firing are opening/closing properly. Sounds like more than one problem but I'd concentrate on getting all cylinders firing first.
Old Aug 18, 2007 | 03:41 PM
blue68f100's Avatar
blue68f100
Re-check your timing, May have jumped a timing chain.
gsr9395
Jul 3, 2010 06:50 AM
Aussie Effie 250
Apr 15, 2010 05:20 PM
diskfunk
Jun 17, 2007 09:47 PM
Flywest
15
Nov 26, 2006 09:58 AM
Plough
Apr 16, 2004 11:16 PM
