another tranny inquiry
Old Dec 11, 2006 | 07:17 AM
Mounter's Avatar
Mounter
1999 Explorer 4x4.
This just started Saturday. When driving just before shifting into another gear it will rev about a 1000 RPM for an instant then shift and drop to normal. This only happens when I am just driving normally from a stopped position. I had to give a bit more gas this morning on my way to work and it did not happen? Then a block or 2 from work my O/D off light began flashing constantly. I have not had anytime to crawl underneath this thing to do a visual check, but I am wondering if anyone has seen or heard of this problem and fixed it without a new tranny. Thanks for looking and i appreciate any help that is given.
*edit* I just found the post by EricW. closely about the same issue and getting the codes pulled today. but any other insites are still appreciated
Last edited by Mounter; Dec 11, 2006 at 07:22 AM. Reason: found something in forum...
Old Dec 11, 2006 | 09:36 AM
aquanaut20's Avatar
aquanaut20
sounds like a shift flare, when was the last ime you changed the fluids. Commonly caused by sticky shift solonoid or a leaky valve plate/gasket.
Old Dec 11, 2006 | 10:08 AM
Mounter's Avatar
Mounter
was a little bit ago but the fluid levels were kinda low just now. Think i'm gonna get a change today and maybe a flush as well. Thanks
Old Dec 11, 2006 | 10:34 AM
aquanaut20's Avatar
aquanaut20
Low fluid level with cause a flare as well, will burn clutch plates as well.
Keep an eye on that level and if it goes down again you need to find out where it is going.
Old Dec 14, 2006 | 08:17 AM
Mounter's Avatar
Mounter
Well got all the fluids and filters changed and flare is still there. Went and had free estimate done at tranny shop and had codes pulled. They didn't give them to me since was just a free estimate. Long story short they're sure that Third gear is shot and needs to be inspected visually. So the tranny needs to be pulled out of there to fix that forsure and then they can visually inspect the rest. All this for 1200 - 2500 bucks.
Old Dec 15, 2006 | 10:19 AM
l-m tech's Avatar
l-m tech
most of the trans ive done in the dealer came in with a third gear incorrect ratio all it took was a new valve body.most have been50 to 85 k.the only other thing could be a worn servo bore which would require a tear down and install a servo bore bushing for the od and intermediate servos.
tjc295
Oct 29, 2010 04:23 PM
Douglas Walker
1997 - 2003 F150
Apr 30, 2010 11:03 PM
romcjr
Oct 9, 2005 10:21 AM
t-burd
Dec 5, 2003 02:32 PM
jfrank
Nov 5, 2003 02:56 PM
