Hot start Issues
Old Dec 10, 2006 | 03:19 PM
bc56845's Avatar
bc56845
Hot start Issues
I changed the fuel filter on my '99 last week and ever since I've had some hot start issues. After the truck has been driven for a while and it's good and hot, it takes about 2 or 3 seconds longer to start than normal. Once it starts it runs fine, it just takes a little longer to crank. If you cut it off and immediatly start it back, it does fine, it's mainly when it sits for a few minutes before you start it back that it does it. I pulled the filter cap back off and checked that the beveled gasket was straight and made sure the lid was tight, I'm not sure if I got air in it or something when I changed the filter? Any ideas? Thanks
Old Dec 10, 2006 | 03:21 PM
bc56845's Avatar
bc56845
One more thing- I checked the level of the HPOP and it was less than an inch from the top
Old Dec 11, 2006 | 12:24 PM
bc56845's Avatar
bc56845
Any Ideas?
Old Dec 11, 2006 | 12:33 PM
Uzumati's Avatar
Uzumati
My only guess would be thinning oil. when you cut it off and imeadiately restart some of the residule pressure is still there but if you let is sit a bit it has a chance to drain down. Cold start is fine right? how many miles on and weight of oil?
Old Dec 11, 2006 | 01:33 PM
tjbeggs's Avatar
tjbeggs
common cause of hard restart when hot is Injector Pressure Regulator (IPR)o-rings. I would bet that it's just coincidence that it started after the filter change
Old Dec 12, 2006 | 06:19 AM
bc56845's Avatar
bc56845
I changed the oil at the same time I changed the fuel filter last week. I used 15W-40 Rotella like always, but I did notice that Rotella had changed the label on the jug. Is it possible that Rotella's oil is a little different now?
How hard are the IPR o-rings to change?
Old Dec 12, 2006 | 08:23 AM
tjbeggs's Avatar
tjbeggs
rotella has been changed due to the low ash requirements coming out for 07 i think. but it should no affect the driveability of our trucks. here is an article on IPR removal and service. you probably don't need to do the complete service like the article shows but just replace the external o-rings. If i remember correctly there are three. Just make sure you get the square cut ring in the correct position.
heres the link
http://cw-diesel.com/LuxSite/IPRInfo.htm
Old Dec 12, 2006 | 09:42 AM
pullinair's Avatar
pullinair
What about all other o-rings that go on the filter itself? Did you check to make sure they were present? There should be one at the base of the filter, inside, center, (1" I think, already installed) where it slides onto the housing. There should also be one the bigger o-oring as wide as the filter that you install on the top outer part of the filter in the groove. And then filter lid gasket that has the bevel and goes on the lid sealing surface.
Old Dec 12, 2006 | 09:01 PM
bc56845's Avatar
bc56845
Sounds like this job would be easier with the intake and boots removed. I've been planning on cleaning or replacing the boots anyway, so I'll just do the o-rings this weekend along with the boots. Thanks guys
Old Dec 13, 2006 | 07:42 AM
bc56845's Avatar
bc56845
I just found this guy on ebay that has new IPRs for 75$. The dealership wants 40$ for just the o-rings. Do yall think it's worth it to buy the whole IPR?
http://cgi.ebay.com/ebaymotors/NEW-P...QQcmdZViewItem
Old Dec 13, 2006 | 07:56 AM
tjbeggs's Avatar
tjbeggs
can't hurt if you have the extra cash. it would also mean you don't need to clean the IPR either.
Old Dec 13, 2006 | 09:48 AM
bc56845's Avatar
bc56845
This seller on ebay says the IPR will fit all '99-03 trucks, but the early '99 trucks, which is what I've got, have a smaller HPOP, right? So will the sensor that fits all 99-03 fit this truck?
Old Dec 13, 2006 | 10:09 AM
tjbeggs's Avatar
tjbeggs
I am not sure on fiment issues. I am pretty sure it will go in and work just not sure if it will right if is not the right part number. Somebody here will know.
coreyallan01
13
Nov 29, 2014 08:41 AM
rallen45107
Jul 7, 2013 12:17 AM
firedaniel
Apr 5, 2012 09:48 AM
wburge
Oct 17, 2011 05:06 PM
doghausbass
Jul 7, 2008 08:15 AM
