I need brighter headlights, help
Old Dec 11, 2006 | 11:29 AM
tdister's Avatar
tdister
The stock bulbs are 9145 and 40 watts. If you are going to use another bulb in their place, use a 9006 bulb. It has the coating on the tip of the bulb and is 55 watts (no matter what it says it equals, it is not 110 watts). You're still taking your chances using it.
is300wrx: Do you have a pic of the beam from your HIDs up against a wall so we can see the pattern/cutoff? I'm just wondering if it is as bad as the units I've had experience with. There is a newer SuperDuty driving around with them in the 9008 version and they are very annoying, haven't seen them in a new F150 though.
Old Dec 11, 2006 | 05:13 PM
is300wrx's Avatar
is300wrx
I can post pics later. The only pics I have of the HIDs is my avatar.
PS. I think I was one of the first to try out the HID system in the newer F-150 and I love the difference. I have Xenon lighting in all of my cars and I just can't go back to the obsolete technology of halogen.
Old Dec 12, 2006 | 10:14 AM
jaym69's Avatar
jaym69
You need to watch putting higher wattage bulbs in your fogs. I have a 2006 F150 Supercrew XLT and my foglight lenses started to melt when I put 42 watt bulbs in, factory is 40 watt. I switched back to factory bulbs and I need to replace the lenses sometime. You have to watch the plastic lenses, I guess they can't handle the heat.
Old Dec 13, 2006 | 12:12 AM
is300wrx's Avatar
is300wrx
From what I see, the newer round fogs, 2006 and up, have less air room for the hotter bulbs to not be able to dissipate the heat. The rectangle fogs have more room and people are not having the problem you mentioned. It is definitely a known issue of melting lenses and wire harnesses by putting in a hot bulb in the aftermarket industry, but I guess people with the square fogs are having better luck.
Old Dec 13, 2006 | 12:00 PM
don766's Avatar
don766
pictures
Originally Posted by bigblueovalman
I added a Westin Bullbar to the front of my '06 150 and installed a set of KC Highlites "daylighters" and hooked them up so they come on with the brights, believe me, I live in elk country and now I can see 'em waaaay out there. Also a good looking addition to your Ford.
Do you have any pictures to the truck with the Bull Bar on it, I was thinking about adding one to mine.
Wayne J
1997 - 2003 F150
Dec 17, 2015 09:49 PM
ALR1955
Mar 26, 2015 05:00 PM
ultrasks700
Jun 9, 2014 07:04 AM
2006LJ
Jan 16, 2014 10:01 AM
lpbaca
Oct 30, 2013 01:06 AM
