tps adjustment voltage
Old Dec 8, 2006 | 06:29 PM
jobrist's Avatar
jobrist
Question tps adjustment voltage
What is the voltage on tps for a 1990 f350 diesel 7.3 with an e40d trans?
Old Dec 8, 2006 | 08:43 PM
bl311's Avatar
bl311
jobrist, This is from another post. I set it to these specs and it works well.
FIPL ajustment.- Truck off, power on, middle wire, 1.1 V at idle postion, 3.8V- 4.3V at wide open throttle
Old Dec 8, 2006 | 09:06 PM
jobrist's Avatar
jobrist
for some reason mine is oposite im getting 3.96v at idle lower at wot
Old Dec 8, 2006 | 09:13 PM
KJLYPW's Avatar
KJLYPW
Maybe its possibly installed with the sending unit 180* off?? Try removing it from the IP and see if you can get the readings to work out right, my connector plug is forward of the TPS mounting screws. If not you need a new sending unit.
Idle to WOT is only about 1/4 revolution of the shaft, can you get it to adjust to the right specs.
Old Dec 8, 2006 | 10:25 PM
roamer37's Avatar
roamer37
take it back off check the voltage it should be low then.. you have to make sure the square part on the shaft is in right you may have to twist the tps a bit to make sure it engages correct..
Old Dec 9, 2006 | 04:39 PM
jobrist's Avatar
jobrist
Nope still high at idle, only goes on one way.sensor is bran new!Even when its not on throdle body.
Old Dec 9, 2006 | 05:46 PM
KJLYPW's Avatar
KJLYPW
I don't know, but is it possible the FIPL (TPS) you have is the incorrect part. Does anyone know if there is a differance between an older diesel part as compared to a newer one off gasser or PSD?? One other thought, confirm you are measuring voltage from a probe slipped in along side the middle wire with the positive side of the voltmeter, the ground directly to negative post on battery, or in other words your not just measuring voltage drop across the entire potentiometer by selecting wire 1 or 3 as your ground?
Old Dec 10, 2006 | 10:07 AM
roamer37's Avatar
roamer37
There are different TP sensors some turn clockwise somr counter clockwise check to see which way yours turns and check the end of the throttle to see if they match
Old Dec 10, 2006 | 06:25 PM
CheaperJeeper's Avatar
CheaperJeeper
I don't mean to hijack, but I have a couple of questions about this part.
Does it mount on the IP? Could someone post a picture of it?
Thanks in advance....
Old Dec 10, 2006 | 11:35 PM
bl311's Avatar
bl311
CJ, No pics because it's dark out. Its easy to find. Its mounted on the drivers side IP and has a terminal plug coming out one end. It's right over the advance lever.
Old Dec 11, 2006 | 05:54 PM
CheaperJeeper
Interesting. Sounds like the same mounting location as the VRV for a truck like mine with the C6. That would make sense, since it essentially does the same thing for the E40D that the VRV does for the C6 - determines the throttle position for purposes of controlling tranny shift points...
Old Dec 17, 2006 | 07:42 PM
jobrist's Avatar
jobrist
ok put the neg. on the battery this time,pos, on middle got the right reading now,set to 1.2v trany shifts much better now thanks! sombody else said you can go all the way to 1.4v to get the tcc clutch chatter out but be carefull might set default mode.
pross
13
Aug 15, 2024 04:30 PM
tjc transport
Modular V8 (4.6L, 5.4L)
May 29, 2016 08:46 AM
Strokerboy73
Mar 23, 2016 04:04 PM
markes12344
Dec 21, 2013 03:20 PM
96Bronco1
1978 - 1996 Big Bronco
May 12, 2010 05:37 AM
