04 5.4 F350 low tps voltage.
Received 3,090 Likes
on
after the cab swap my 04 F350 with 5.4 is throwing a low tps voltage code, and a vss code. everything works though.
the transfer case is not plugged in, because the new cab wiring was not compatible with the old one, and was off a 2 wheel drive. i don't think this would cause the problem though.
where is the tps on this engine, and is it adjustable, or do i just change it?
edster
09-01-2009 07:11 PM
