I would like to get my in tank mods done soon. I have the dahl 150 filter. The problem is i don't know what size fittings to use on the connections. Does anyone know or have this filter and be able to tell me the size of the connectors? Also where is the best place to get replacement filters for this and how often should i change them. Also what micron filter should i use, they have the 2, 10, 30? thanks
I know from advice on the forum that the ports in the fuel filter are #10 (10/16, or 5/8") o-ring boss hydraulic fittings. Ive checked all of my local places and no one has it. If anyone would like to point out on the internet where these can be found for me and this guy?
Kris, i am going to do some looking around here today. If i can find some i will pick up extra and ship them to you. Otherwise if someone knows where we can order them threw and have a link that would be great. Thanks
I got my fittings from Bob at dieselsite.com when I ordered the Dahl from him. I don't think he has them listed on his site but it my be worth a call if you don't find them anywhere else.
great selection, no minimum and decent flat rate on shipping. Got my baldwin fuel filter base fitting and hutch mod fittings there. They even had a 5/16-3/8 compression fitting so I could use 3/8" line on both pick up and return lines.
Looks like they have a ton of fittings. I looked for the 5/8 o-ring boss hydralic fitting and didn't come across anything. Maybe when kris sees this he will know which ones are the right ones. Thanks
I just checked dieselsite.com and since a ordered my filter about a month ago he added a bunch of stuff and has a kit for installing the dahl filters that comes with the fittings. http://www.dieselsite.com/index.asp?...ROD&ProdID=553Thanks guys
