For Dahl 100 users
Old Mar 10, 2007 | 12:59 PM
firemediceric's Avatar
firemediceric
For Dahl 100 users
For you guys with the Dahl 100 fuel filter, what does your vacuum guage at the filter read?
I just installed my Dahl unit and I am reading -11 on the guage. Some that I have mentioned this to say that seems high?
What reading should I expect as the filter becomes restricted enough to affect fuel flow? I'd hate to burn up the pump.
Old Mar 10, 2007 | 03:46 PM
SpringerPop's Avatar
SpringerPop
I don't have a gauge on mine, but if I recall correctly, I think the number is something like 7-1/2.
But that's assuming my memory is still intact..... ;-)
Pop
Old Mar 10, 2007 | 04:07 PM
Fat Diesel's Avatar
Fat Diesel
That is high. I read around 2-4 when I have a new element, and as high as 15-20 when I need to change it.
Old Mar 10, 2007 | 04:39 PM
firemediceric
Well, if my reading is high, what would you attribute it to and what course of action would you recommend I take?
Old Mar 10, 2007 | 05:51 PM
Fat Diesel's Avatar
Fat Diesel
Hang on. Have you done the in-tank mods and ditched the screen in there? That *might* be the reason for it being high if it's still in there. I have removed mine and have just a tube for fuel intake.
What does the fuel pump sound like when you turn the key on but not start it? If you hear a buzzing or bubbling sound, your pump is yelling at you to find the restriction. That is what prompted me to check my gauge and see it was clogged. It took over a year to clog the filter to that point.
Old Mar 10, 2007 | 08:15 PM
firemediceric
I have not done the in tank mods yet. I'm trying to get someone that is close by with a little more faith in their mechanical abilties than I have in mine to help me drop the tank.
Sitting in the cab, after having purged the air from the filter, I have not heard anything noticable with the pump. Maybe I'll lay down there while I have someone else cycle the key.
If my pump is dealing with restriction, in addition to sound wouldn't I feel it with lack of acceleration?
Old Mar 11, 2007 | 01:22 PM
firemediceric
Cool
I removed the Dahl from the fuel line and the guage now reads -8. That still seems higher than what you guys are reporting. I'm wondering if I should just continue to run the filter as is and see what happens or what?
I'm starting to regret this measure that I took in an effort to ensure the quality of my fuel.
Old Mar 11, 2007 | 01:47 PM
TNT in Round Rock's Avatar
TNT in Round Rock
Eric .. what part of the country do you live in ?
Old Mar 11, 2007 | 02:33 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I know this may just be a band-aid fix for a high restriction in the system, but adding a lift pump between the filter and the main pump will help greatly on extending the main pump's life. It really hurt's it's efficiency when you have that restriction in the system and the pump has to pull the fuel and then push it as well. The lift pump running 5-7psi of pressure will pull fuel from the tank, through the filter, and then send it on it's way to the main pump. I have a Carter 4070, but the only disadvantage is that it is extremely loud compared to the stock pump. It is about $60 and i think it's worth it.
Old Mar 11, 2007 | 02:55 PM
ernesteugene's Avatar
ernesteugene
I just had a Racor installed, and it came with their recommended 30 micron element on the suction side. They also make 2 and 10 micron elements that fit my adaptor, but claim they should only be used on the pressure side of the OEM pump. I'm wondering if the smaller micron filters cause too much restriction when used on the suction side?
Old Mar 11, 2007 | 03:01 PM
John311t's Avatar
John311t
You can use a lift pump so that on the suction side you can use the 2 micron filter IIRC. Thats my next mod.
Old Mar 11, 2007 | 03:20 PM
ernesteugene
Does a FASS or Air Dog system qualify as a lift pump? They seem to be installed so that they feed into the OEM pump intake. Before spending those $$, I'm wondering if I can install a second 2 micron Racor on the pressure side of the OEM pump and try to make my own air separator as discussed here.
https://www.ford-trucks.com/forums/585815-possible-new-fuel-mod-for-air-separation.html
That would make a total of 3 filters for the OEM pump to flow, and maybe that's too much total restriction?
Old Mar 11, 2007 | 03:47 PM
firemediceric
Thanks for the suggestions
I live in Vero Beach, FL.
I blew some compressed air through the fuel lines and back into the tank, thinking that maybe the tank strainer may be obstructed. I hooked the Dahl unit back up and started up the truck.
Where I was reading -11, I am now reading -8. It stands to reason that if I removed the Dahl unit at this point I would read -4. So things are better, but still not great
I guess I need to plan on dropping the tank and doing the Hutch Mod? Anybody close by feel like heping me out with that task?
If that still does not remedy the situation I guess I will be looking for a lift pump. My wife will love to hear that I have to spend yet more money and time for what was suppossed to be a simple up-grade.
I read that I want a pump that pushes out 5-7 PSI and I saw the recommnedation of the Carter pump. Any other LOW cost suggestions?
Old Mar 11, 2007 | 04:01 PM
ernesteugene
Where I was reading -11, I am now reading -8. It stands to reason that if I removed the Dahl unit at this point I would read -4. So things are better, but still not great.
Looks like you're in tank strainers are starting to look like the one to the left in this pic Click for full size image
Old Mar 15, 2007 | 06:48 AM
firemediceric
I dropped the tank, I did the Hutch and Harpoon mods. The screens both on the foot and in the mixing chamber were VERY clogged.
I got new 3/8" fuel line run and everything is back together. The truck seems to be running well and the Vacuum guage after the Dahl is now reading -4.
Had I never purchased the vac guage from Bob, I would have never known about this problem until I went through several pumps . As it is, who knows how long I've been dealing with this restriction and placing a strain on the pump.
Eric
