How accurate is the "Temperature" gauge?
#31
This is as close in writing I have from the PCED...
Note: The Engine Temperature Warning Indicator (gauge or lamp) is a warning system that gives the driver information during an engine overheating condition. The PCM monitors the CHT sensor and determines if fail-safe cooling mode is needed. If fail-safe cooling mode is needed, the PCM can signal the driver in 2 ways:
Temperature Warning Indicator information received through the vehicle Communication Link (SCP or CAN):
The PCM sends a SCP or CAN message to the instrument cluster to signal an overheating condition. This causes the instrument cluster indicator to illuminate and/or forces the temperature gauge to the H (hot) zone. DTC P1285 will also be stored in the PCM.
#32
#34
Originally Posted by 04 FX4 Lineman
Nice job, how many miles did those pugs have on them when you pulled and did you have much difficulty getting them out??
http://video.google.com/videoplay?do...44263925431728
BGF100
18
01-03-2017 09:42 AM
CrispyWafer
12-29-2016 10:38 PM
hobo99
11-21-2016 05:36 PM
davelength
11-23-2010 05:00 PM
