Temp. Sending unit
Old Aug 25, 2016 | 10:54 AM
S.P.'s Avatar
S.P.
Temp. Sending unit
I'm told there's two temperature sending units on the engine one for the gauge and the other to tell the transmission that the engine is up to temperature... can anyone tell me where the second one listed is located? And how can I fool the trany to think the engine is up to temperature?
Old Aug 25, 2016 | 11:11 AM
ifrythings's Avatar
ifrythings
There's only one temp sender on theses engines and it's for the gauge, there is also a temp switch for the high idle and timing advance but neither of those go to the TECA.
There is a transmission oil temperature sensor in the solenoid pack inside the transmission, the only inputs the transmission gets from the engine is tach and throttle position.
Old Aug 25, 2016 | 11:48 AM
awhtx's Avatar
awhtx
There is a relay for the TECA located in the wiring harness for the right side glow plugs and the wiring to the Cold Idle Solenoid, Cold Idle Timing Advance and FSS. The Cold Idle items are activated/deactivated by a temperature controlled On/Off (ON less than 112*, OFF above 112*) switch located in the forward end of the right head, underneath the radiator hose neck on the thermostat housing.
There are 4 wires to the TECA Relay and it is quite possible that the temperature On/Off switch affects this wiring.
Old Aug 25, 2016 | 12:22 PM
ifrythings's Avatar
ifrythings
Those are two separate systems on these trucks and have no interaction at all.
Is your od light blinking? Tach working? Those will tell you if the TECA Relay is working.
Old Aug 25, 2016 | 01:50 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Dave Sponaugle - Water Temp locations
-Enjoy
fh : )_~
Old Aug 27, 2016 | 11:27 AM
S.P.'s Avatar
S.P.
The tach works and the OD light doesn't blink... could someone tell me where the wires are and what they/the connector looks like that goes to the transmission? Thanks.
96 D.I.T
Sep 2, 2011 12:45 AM
DMiles411
Aug 10, 2011 05:58 PM
tjc transport
Feb 14, 2006 08:48 PM
nmfordguy
Nov 29, 2005 02:52 PM
redrumybronco
1978 - 1996 Big Bronco
Jul 7, 2004 05:31 PM
