TPS Sensor!
Old Dec 7, 2006 | 08:33 PM
Hendricksbus's Avatar
Hendricksbus
Question TPS Sensor!
Will a bad TPS sensor cause a drop in the idle!or a miss in the idle? My friend say too change the TPS sensor!!
Old Dec 8, 2006 | 10:50 AM
subford's Avatar
subford
No not likely. If the TPS says the throttle is more open than it is it could dump too much fuel in it and you would have a miss at idle with black smoke out the tail pipe.
The TPS tells (in conjunction with other sensors) the EEC Computer how much fuel to put in the engine, how much to advance the spark and when to shift the transmission.
NotEnoughTrucks2014
Mar 5, 2017 12:37 PM
green_95
Sep 3, 2015 09:27 AM
markes12344
Dec 21, 2013 03:20 PM
Jrock909
Jul 29, 2006 02:00 PM
SupaFord95
1978 - 1996 Big Bronco
Aug 20, 2003 01:28 PM
