1978 F-150
Old Dec 6, 2006 | 03:52 AM
78_79ford's Avatar
78_79ford
Thumbs up 1978 F-150
when I looked up my vin numbers for '78 F150, I suspected that the 460 V-8 was stock, but I didn't know it came with a 4 barrel carb stock, did they ever come with 2-barrels? I know my '79 Bronco i just sold had a 400 V-8 with a 2 barrel
Old Dec 6, 2006 | 05:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 351M and 400's all had 2V carbs...at least in CA..some of them were the dreaded variable venturis. The 460's...in the 70's trucks were 4V's.
Old Dec 6, 2006 | 05:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
There have been a couple of reports of factory 4V manifolds for the 351M/400 but they had experimental part numbers and probably were spirited out of some factory R&D center. The only US production manifolds were 2V manifolds with 2V carbs of course. You can check with the 385 engine forum, but all of the 460's I have seen had 4V carbs. The truck in a thread here supposedly has a 2V 460 in it. Calls it sluggish which may be from the 2V and maybe why all I have ever seen were 4V.
https://www.ford-trucks.com/forums/5...g-on-ebay.html
The picture below is purportedly to be a factory 4V for the 400 the number on the manifold seems to be 13726548 which would be correct for a 400 and not a 460.
Old Dec 6, 2006 | 06:18 AM
LxMan1's Avatar
LxMan1
That's definately a 335 series intake. Possibly a 351CJ, but I would have to see the port size to verify that.
That Ebay truck has a transplanted 460 (came with a 400) with an Edelbrock Performer 4V manifold with a 2V to 4V adapter plate. No wonder it runs crappy.
The heater controls look just like the ones in my sister in-laws Geo Storm.
Old Dec 6, 2006 | 06:20 AM
NumberDummy
I'd like to see what the engineering (casting) number that 2V 460 intake manifold has...it could be off a 429 engine from the late 60's or early 70's.
Sample: C8VE-9424 (or 5)-AA
Old Dec 6, 2006 | 08:21 AM
darrin1999's Avatar
darrin1999
yep... all 460s had 4 barrel carbs from the factory... only the 429 had the 2 barrel option, so if someone says its a 460 2 barrel its either a 429 or has a 429 intake on it
Old Dec 6, 2006 | 02:35 PM
Mil1ion's Avatar
Mil1ion
I'd say it is off a 351C.
Post ALL the casting numbers or is that not your intake Eric?
I'd say an early 70's.
Most 68/69/70 429/460 intakes were square bore not spread bore like the one shown.
The spread bore was on the clevo.
Btw, please put the Topic in the title
ie: 4v 351M/400 Intake ?
someone looking for the same info would not know to type 1978 F150 in the search feature in the "title" for this thread.
Old Dec 6, 2006 | 02:37 PM
Mil1ion's Avatar
Mil1ion
1968 429 ThunderJet C8VE-9425-A or B
1969 429 ThunderJet C9VE-9425-A or B.
If that 460 in thr OP is 2v it is more than likely a car intake.
SC78f150
Feb 20, 2014 02:59 PM
Lumpy78
May 4, 2010 11:25 PM
ssanto
Jun 10, 2006 09:09 PM
miichael
16
Mar 4, 2006 10:00 PM
Ford78_302
May 3, 2000 03:23 PM
