Offroad & 4x4
Update on 4x4
Old Dec 5, 2006 | 07:31 PM
FordF350Baby's Avatar
FordF350Baby
Update on 4x4
On the way home today, I figured I would try the 4x4 out. For a one mile stretch, I let the truck run in 4 high. I pulled into a parking lot, and tried to get it into Low. No such luck, wouldn’t budge. My biggest concern is, when the hubs are locked and I am taking a turn, there is the incredible force against the steering wheel, a uncontrollable rocking of the steering wheel back and forth. Now I know there’s going to be a lot of tension on the steering wheel when your on dry pavement, but it was at the point where I couldn’t turn the wheel because it was dragging so bad, and the wheel was jerking very hard. This violence in the turning leaves me to believe why the 4 Low wont go in, and also have a feeling the 4 high may not be working, and just the hubs are locking in. Any ideas?
Old Dec 5, 2006 | 07:58 PM
Bandit-1's Avatar
Bandit-1
If just the hubs are locking you wont feel anything, i would try the 4x4 on dry pavement bad for it.
Old Dec 5, 2006 | 08:44 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
DO NOT USE 4LO ON PAVEMENT!! And DO NOT make sharp turns in 4hi.
Old Dec 5, 2006 | 08:49 PM
FordF350Baby
Yeah I know, I was only trying it. I told ya on knew it was bad, but I am experimenting with the 4x4. I guess I will just have to see its potency when its snowing. Which to looks of it will never happen here in Maine.
Old Dec 5, 2006 | 09:39 PM
captain p4's Avatar
captain p4
I'm telling you, bring that truck over here and drop it off, I think I can manage to put up with those pesky hubs.
What you describe is completly normal for the 4wheel system. If you want to play around with it find a gravel road before you break something messing with it on the pavement. Remember to put it in neutral and step on the brake, you might also have to rock the truck around a little bit when you try to shift it. It probably wouldn't shift because if got bound up running down the highway.
Old Dec 5, 2006 | 11:16 PM
jcg82's Avatar
jcg82
4x4 drive is not for pavement. Like captain said that is normal. If you wanna play go find a muddy ditch to drive through.
Old Dec 6, 2006 | 02:17 PM
FordF350Baby
MMKkk, cant use it today, getting the A/c clutch replaced. Err, good thing its warrantied. friggen noise was driving me crazy.
Larry00663
Mar 15, 2016 09:29 PM
deputydog03
Dec 10, 2015 07:40 PM
dpty22
Jan 25, 2013 01:04 AM
Sigskydiver
Jun 4, 2012 08:39 AM
M88
Sep 3, 2010 07:40 PM
