GM cs130 alternator
I agree with Chad completely. FoMoCo uses external regulation as a safety valve.
FoMoCo externally regulated style Alternators go from $29.95 & up for a rebuilt and Regulators go for $8.95 and up with a good one going for around $15-$18. So a well rebuilt Alternator for 49.95 and a good regulator for $18 is what worse case $67.95? But the worst case with a FoMoCo system usually is just a regulator, or if you jump a lot of people or get jump started a lot, a diode array in your alternator. $18to $30.00, right?
A 1 wire Alternator is roughly $120. You'll have to create alternator to your system wiring with fuse link. Everytime it goes bad (they do go bad) it all goes bad which = a new alternator and in that scenario, it's another $100+ Repair Where is the advantage or logic to that change. . . . .
IF you use regulator as a sacrificial safety fuse, you're out the price of a regulator, $8.95 to $18.00. But when a 1 wire Alt goes out, you're out a $100-$120 Alternator.
FBp
FBp
on
Yup! I use a GM 12IS about 100 amps + or -. Wrote a technical article about it here. Easy swap costs less than a 100 bucks and solves a bunch of rotten wire and multiple connections issues. Ford stuff works well its just that I prefer a reliable easy to install charging system. I drive my truck every day. Read the tech article and post back with specific questions if you need help. IMHO!
I shoulda known this was a trick question & you were going to change to a GM alt. all along since you have done it 3 times already. Why bother to ask, if it's your intention, to do it so we can waste our time?
That's what is AWESOME! (and a tad rude too)
THANX . . . . . . I'll remember it
Oh, BTW A more powerful charging system does not give you more powerful ignition. 12v = 12v no matter how many amperes are involved.
FBp
FBp
544tess
12-11-2016 11:51 AM
