Fuel tank strap insulation?
Old Dec 4, 2006 | 07:23 PM
jroehl's Avatar
jroehl
I recently found a very small leak in my rear tank, so I ordered a replacement along with new straps. However, I suspect the leak was due to the insulation/padding being worn out, and the new parts didn't come with any insulation. Where might I find some, or is there a good substitute?
Jason
Old Dec 6, 2006 | 06:33 AM
jroehl's Avatar
jroehl
Shameless bump to the top.
Jason
Old Dec 6, 2006 | 07:19 AM
currituckF150's Avatar
currituckF150
Why don't you use some camper shell foam tape? Cheap & durable.
Old Dec 7, 2006 | 07:26 AM
mississauga's Avatar
mississauga
I think the leaks around the straps are caused from moisture sitting in the crevices created by the straps. I have siliconed strips of rubber to straps that I have replaced in the past. I would stay away from anything that holds moisture. Some people have use inner tube rubber. I have used a pvc material used to line household shower stalls with to keep them from leaking.
Old Dec 7, 2006 | 07:01 PM
SilverSport's Avatar
SilverSport
I think rubber would hold the moisture in. I just change my front tank pump ... and had the tank out, have removed tank from 73 Mach also ... I think the stuff the factory uses is closer in nature to a heavy roofing felt ... more than the 30lb stuff at the Depot ... but some of that folded over into 2 or 3 layers should be about right, and it will allow water to dry instead of pool up like what whould happen in rubber.
Brother Hec
Apr 11, 2016 01:12 PM
Pappys53
Oct 28, 2014 08:39 AM
BossFan
Jul 31, 2011 03:09 PM
farmnaggie
Apr 17, 2011 09:15 AM
XLnAK
Oct 29, 2006 04:19 PM
