Gas Tank Replacement
Old Apr 11, 2016 | 10:29 AM
Brother Hec's Avatar
Brother Hec
I have 79 f150 4x4 with a metal tank in rear. I have taken out the tank to replace hoses (leaking) and remove rust from outside of tank. I will be repainting tank and metal holding straps before replacing. Question is whether tank will require a ground so that float/gauge will work? I plan to replace rotten canvas liners inside metal straps with rubber so that that tank does not rub with metal straps and cause holes. If so, then it will insulate tank from frame. Do I need to wire a ground strap from tank to truck frame?? Please advise me on best way to make sure the electrical float/gauge will work.
Thanks,
Brother Hec
Las Cruces, NM
Old Apr 11, 2016 | 11:01 AM
HoustonDave's Avatar
HoustonDave
Your sending units has a separate ground which screws to the frame... just dropped my tank this weekend to extend the float arm to make a 19 gallon sender work better with a 38 gallon tank.
Old Apr 11, 2016 | 11:10 AM
Brother Hec
Thanks for the reply. My old tank did not have a ground connection from sending unit to frame. This is why I was thinking ground was through tank connection with metal straps. I will make a connection from sending unit to frame... good idea, THANKS!
Old Apr 11, 2016 | 11:24 AM
HIO Silver's Avatar
HIO Silver
If in doubt, add a ground.
Ya can't have 'too many grounds' on these trucks.
Old Apr 11, 2016 | 11:52 AM
hasteranger's Avatar
hasteranger
Yeah sending unit has its own ground and that ground being bad is a common source of failure...but tank itself doesn't have or need a ground. My tank is plastic.
Old Apr 11, 2016 | 01:12 PM
HoustonDave
I'll vote with HIO - it's never a bad idea to have a spiffy ground when you have a tank full of explosive which can be set off by a spark. Odds are that it is probably unnecessary... but the odds are that no one would ever hit a winning lottery number, either.
brendaf150
Oct 22, 2013 05:08 PM
nolan62
28
Apr 17, 2012 03:15 PM
reed1951
25
Apr 18, 2008 08:21 AM
gray91
19
Aug 4, 2007 07:06 PM
mallardgreen
Aug 26, 2003 04:31 PM
