General Automotive Discussion
hydraulic dump-box pump
Old Dec 4, 2006 | 11:24 AM
nebechanezer's Avatar
nebechanezer
i am planning on putting a dump box on my truck. the dump box has a pto-powered pump mounted on the resevoir (sp), mounted on the frame of the truck i'm taking it off. i am going to put it on a truck w/ a c6 auto, so i'm planning on using a belt driven pump on the front of the engine. i can get the pump from some ag equipment, along w/ some vavles and hoses. do i need to have a tank mounted at the same height as the pump, or can i mount one on the frame. will it draw oil up to the pump?
Old Dec 4, 2006 | 05:50 PM
tjc transport's Avatar
tjc transport
i ain't rite
why not run the pto off your transfer case ??
most t-cases if have seen have a pto window in them
Old Dec 4, 2006 | 07:35 PM
nebechanezer
that's and option, i guess, but i was thinking if i had a crank-driven pump i'd use that to run my snowplow too. where would i get a pump to bolt to the t-case? Are they the same as ones that bolt on man. trannys?
Old Dec 4, 2006 | 10:16 PM
85e150's Avatar
85e150
Them pumps gotta clutch or something? You don't want that thing spinning all the time....
Old Dec 4, 2006 | 10:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
It is best to run a flooded pump inlet. To do that the reservoir is above the pump or at the same level. It is possible to have the reservoir below the pump but that can cause some problems.
The pump should have a clutch unless it is in continuous use for some purpose. Electric motor driven pumps are a good choice for applications that do not require continuous pump output.
When building a hydraulic system get some help from a trained hydraulic technician. Hydraulic systems can be extremely dangerous.
Old Dec 5, 2006 | 03:20 PM
tjc transport
i ain't rite
yup. same pump.
Old Dec 6, 2006 | 07:46 AM
nebechanezer
i meant to say pto, not pump, maybe thats what you meant too. would the pto on the trannsmission of my parts truck (4 spd w/ granny low [np 435?] in a '74 f-350) bolt on to my highboy's transfer case (np205) ?
Old Dec 6, 2006 | 03:20 PM
tjc transport
i ain't rite
yea, thats what i meant also. it should. at most you may have to get a different spacer, but i have done it a few times on newer trucks, and everything swapped rite in as long as the gears were a match. the hard part is figuring out the direction of rotation before you screw something up.
Old Dec 6, 2006 | 03:40 PM
51dueller's Avatar
51dueller
You could use an electric pump. I got an old electric hoist. It's pretty much a starter motor hooked up to a pump.
fellro86
Large Truck
Aug 25, 2011 03:01 PM
BlueOvalBud
Aug 15, 2010 10:24 PM
dentvet
Mar 5, 2007 09:55 AM
Broken40
Dec 18, 2006 11:39 PM
badass truck
Jun 12, 2003 01:06 AM
