F600 with dump box, need to swap dump beds
I was wondering if anyone had experience changing the dump beds on these trucks. I have a 15' grain box that it shot, and swapping it with one that came off a truck my uncle flipped. The lift is twisted as he was moving it with the load of grain in it and it tipped over, but the box came out ok, just the truck frame and the lift frame got damaged. My question is more about the upper lift mounts. On both boxes, the mounts are welded in. Am I going to have to get one side loose so I can move it to the side and off the mount? The box I want to put on will be harder to do this, they really got carried away with the welding, even if they are crappy welds... I figure on hacking up the damaged lift to get it off, make it easier to work. It is twisted enough to not be reasonably salvageable anyway.
Turns out, the installers welded the pivots on to both boxes. I was hoping I wouldn't have to hack it all up, but that is basically about what had to happen. The pivots were also in different locations. The box I am putting on had the mounts welded on real well, but crappy welds... This was done by the installers, not the farmers. They just would have bought it. I am referring to the point the hoist mounts to the box frame. I haven't gotten the swap finished, as I found the brake lines leaking fluid, so figured it would be a good time to take care of that as well. Then just haven't had time to get back to it.
I did cut off the lift pivot, as it was located different. It is waiting for me to get the brake lines fixed, then get the box sitting in place so I can set the frame pivot brackets and the lift pivot pipes. I hadn't had the lift off on one of these, was surprised that they are hollow... Made for an interesting time cutting them off with the torch, being full of grease.
SC'79
02-03-2014 10:33 AM
IDIDieselJohn
01-19-2010 12:40 AM
