View Poll Results: Is USLD causing leaks?
My drain valve has recently began leaking.
59.82%
My drain valve leaked and/or was repaied before USLD.
6.25%
My drain valve has never leaked.
29.46%
What's a drain valve and/or I like bacon.
4.46%
Voters: 112. You may not vote on this poll
Leaking fuel drain?
Old Dec 11, 2006 | 09:08 AM
  #46
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Wow, this is a damn epidemic! It must be the ULSD, jeez I just love the EPA. Mine must have showed up so early because I have put nearly 15,000 miles on my truck over the summer and have been using some DK, in fact I feel like I have been using enough so maybe the DK is not going to save us from these types of problems.
Old Dec 11, 2006 | 09:14 AM
  #47
jtharvey's Avatar
jtharvey
Originally Posted by elvis81
Does 20% boidiesel help in lubricating the ULSD?
Yes. Actually anything of 5% bio and over is sufficient lubrication to compare to or surpass the lubricity of the now defunct LSD fuel.
Old Dec 11, 2006 | 11:14 AM
  #48
JUMBO_UTE's Avatar
JUMBO_UTE
Originally Posted by Zephyr
I ordered a set on Ebay (to have just in case), $5 & free shipping.
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Just bought mine today.
Old Dec 13, 2006 | 10:15 AM
  #49
Markadeck's Avatar
Markadeck
Got mine fixed today. Living more or less on the road in my motor home in Florida for the winter I don't really have an address to send anything to. Could not find the correct o-rings at any local parts stores so let the stealership stick it to me for 50 bucks for the entire valve. Next, find a shop to install. Found a man that "does not work on diesels" and with a little begging, a diagram and telling him how easy it was to do with the proper tools he agreed and did it for 30 bucks, about a half an hour and out the door. No more leaks anyway!
Old Dec 13, 2006 | 07:10 PM
  #50
Dave Tyler's Avatar
Dave Tyler
Thumbs up
Sounds like you got a heck of a deal with the labor. The $50. was not that bad for a Ford Dealer. Did you read above where the Dealership charged $296.00 for doing the job??
Old Dec 13, 2006 | 07:13 PM
  #51
Markadeck's Avatar
Markadeck
Yes I did, and I told the we don't work on diesels shop about our epidemic, and how much the stealership wanted for doing what took him about a half hour.
Old Dec 13, 2006 | 08:04 PM
  #52
Dave Tyler's Avatar
Dave Tyler
I have about the same amount of miles, 160,000 or so on '99. Changing the water pump this weekend and reading the hints on this web site. Take care. Are you ever in Texas, you said on the road? Dave
Old Dec 13, 2006 | 11:43 PM
  #53
Stewart_H's Avatar
Stewart_H
Viton
Excellent ozone, weather, synthetic lubricant, animal/vegetable oil, aniline, chemical, and hydraulic fluid resistance.
PTFE
Is the most versatile when it comes to resistance to environments such as tearing, abrasion, ozone, weather, water, steam, acids, alkalies, synthetic lubricants, animal/vegetable oils, anilines, hydrocarbons, detergents, salt water, hydraulic fluid, alcohol, refrigerants, and ketones.
I just ordered a 10 pack of PTFE's to replace my O-rings for some preventive maintenance.
Stewart
Old Dec 14, 2006 | 03:58 PM
  #54
JUMBO_UTE's Avatar
JUMBO_UTE
Ok, I just replaced my o-rings. I got them on ebay. Viton brand. My Excursion has the California emission controls on it and it took me almost two hours to do the job. The wiring harnesses kept getting in the way and I could only turn the ratchet maybe a quarter turn. I just checked for leaks and I'm good to go.
Old Dec 14, 2006 | 10:28 PM
  #55
claydr54's Avatar
claydr54
Does anyone know what the symtoms of the injector o-ring failure will be?
Old Dec 15, 2006 | 12:01 AM
  #56
lionsteve's Avatar
lionsteve
Ok, newbie here. Can someone post up a picture of where this leak is? I am sure I have seen it but want to make sure.... Since I seem to remember smelling fuel a couple of times lately... hummmm????
Steve
Old Dec 16, 2006 | 03:28 AM
  #57
ron's power stroke's Avatar
ron's power stroke
doing my u-joints last night and noticed a drip from my tube..its a small drip now..its never leaked be for now..
a question for you guy's..every one seems to find the leek when the valley fills up or smells fuel...I didn't smell any fuel and my valley is bone dry..the drip is from the tube not the back of the valve...did I just get luck and noticed it be for it got worse or could it be something else??
Old Dec 16, 2006 | 07:11 AM
  #58
Fords4Me's Avatar
Fords4Me
No ron, you just have a leaky valve. this leak won't go down that tube, but the outside of the filter housing and onto the top of the motor.
Old Dec 16, 2006 | 07:33 AM
  #59
ron's power stroke
ill get the valve kit then..wont hurt right?? thanks for the info
Old Dec 16, 2006 | 08:50 AM
  #60
clux's Avatar
clux
Same here, I was under my pickup and noticed the drip from the drain tube, no fuel in the valley of no return.
