97 Hiccup no Code
Old Nov 30, 2006 | 11:24 PM
bkcowboss's Avatar
bkcowboss
Red face 97 Hiccup no Code
Trying to trouble shoot a hiccup while driving on a 97, when I read the codes with actron obd II code reader, I get no codes. I think it the hiccup may be a loose wire , is it possible that my 97 is not OBD II compatible? I have a TS 6 pos chip installed, will that cause a lack of codes. When I mess with the fuel pressure regulator on the back of the HPOP that is when the pickup hiccups and dies, I don't want to replace good parts if I don't have to. I also have read a lot of stuff about the cps but wouldn't that generate a code?
Thanks in advance
Old Nov 30, 2006 | 11:33 PM
IDMooseMan's Avatar
IDMooseMan
My truck started hiccupping on the way home from work tonight. I called my dealership-service-tech-friend and told her what was happening. She said it might be the CPS and yes, it would throw a code.
I don't have a code-reader at this time. I'm looking for one and am not sure what I should get, so I'm no help regarding OBD II-compatibility. Sorry.
Old Dec 1, 2006 | 06:23 AM
bkcowboss's Avatar
bkcowboss
Thanks, at least I know it should throw a code now. I have disconnected the ts chip and I am going to drive it to see if that will allow codes to come through.
Old Dec 3, 2006 | 06:23 PM
bkcowboss's Avatar
bkcowboss
Well I think that I have isolated the issue, it was having the hiccup issue every time that I drove, I disconnected the TS 6 pos switch to see if I could pick up a code to identify the problem, and apparently that was the problem. Driven 3 days no issue, I am going to continue to drive for a week or so, but I think that it was it. I am not sure if it is the chip or a connection. The chip has been installed for a year with no issues, but maybe the wx change caused a poor connection. Is there something that I should use to preserve the connection the the computer terminal when I plug the chip back in?
Peterbilt376x
Mar 10, 2012 10:37 PM
rps58
Oct 26, 2007 08:40 PM
jeffthralls
Mar 14, 2007 08:54 PM
buckskinfordgirl
22
Jan 6, 2005 03:46 PM
