Tranny flush-how to fill it?
on
well assuming you also dropped the pan and did a filter also. add about 7 quarts to the tranny and start it up if you didn't drop the pan and the trans is still full add about 4 quarts. after the truck is started check the level. The TC should hold about 7 or 8 quarts I think. so just add till it good on the dip stick. drop it into gear a few times to be sure everything is full of oil then double check the level.
I'm going to take your question literally, so don't be offended by this reply.
Judging from the wording of your question, I'm assuming you want to know WHERE to add ATF.
Add Motorcraft Mercon ATF XT-2-QDX or Dexron Mercon III through the dipstick tube to bring the fluid level up between the MIN and MAX lines on the dipstick.
