need 2 know: oil pressure
Old Nov 30, 2006 | 08:01 PM
keisha9's Avatar
keisha9
ive got a 360 fe running 50 psi @ 2000 just checking to see what average should be @ ? thanks
Old Nov 30, 2006 | 08:41 PM
slinger34's Avatar
slinger34
I have a 390 that runs at 35-45 psi at 1500rpm or more
Old Nov 30, 2006 | 08:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is that warmed up and hot, or ice-cold?
What weight oil?
50 at 2000 sounds pretty good, if it's hot.
What pressure does it idle at?
Old Nov 30, 2006 | 08:58 PM
slinger34's Avatar
slinger34
At idle mine is into the mid teens. Is that normal
Old Nov 30, 2006 | 08:59 PM
keisha9's Avatar
keisha9
7777i dont know maybe 40....i just went outside and its cold out about 36 degrees and my pressure was 60-70 when i rev it up but it never got hot.
Old Nov 30, 2006 | 09:15 PM
Bear 45/70's Avatar
Bear 45/70
The only spec. Ford gives for FE engines is a minimum of 35 PSI at 2000 rpm. Engine is to be at operating temperature.
Old Dec 1, 2006 | 12:27 AM
1975Ford's Avatar
1975Ford
My truck, with a 390 FE engine, and with a standard oil pump. Runs about 45 to 50 max psi at idle and 55 to 60 max at higher rpms. Hope this helps.
Old Dec 1, 2006 | 06:31 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I have had some FE's that had a little as 10psi at idle about 600rpm..and the went right up after idle to 35 to 40psi...all at operating temp with 30W oil... and with 80 degree outside temps..
And run as low as 5psi in 100 degree temps at idle...and as high as 70 psi at temps befow freezing! as long as you have pressure..I wouldnt worry about it!! and of course bearing clearences have alot to do with it also!! JMO..
RJ
Old Dec 1, 2006 | 10:27 AM
LedheadELH's Avatar
LedheadELH
Yea, it really all depends on how the clearances are. I would say as long as your over 15 PSI at idle, and 30 PSI are any higher RPM, you should fine in a stock motor. Now if it's been rebuilt then it all depends on how it was built, and what type of oil.
Old Dec 1, 2006 | 05:01 PM
customcab66's Avatar
customcab66
I was told at one point that it is ten pounds of oil pressure for every 1000 rpms.
Old Dec 1, 2006 | 07:29 PM
LedheadELH's Avatar
LedheadELH
yea, the 10 psi for every 1,000RPM is what I was taught at school too. Kinda like for every inch in diameter of bearing jouranl, you need .001" oil clearance....or maybe it was .0015, or .002"???....wait....001" sounds right tho
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
