over heating
Old Nov 29, 2006 | 09:23 PM
82Bronc's Avatar
82Bronc
over heating
I'm having problems with my truck overheating, I know its not the fluid cause it stays full and pressurized, I dont think its the thermostate cause the heater always work i need some help
thanks
Old Dec 1, 2006 | 08:26 PM
LedheadELH's Avatar
LedheadELH
A few things can be a bad water pump, clogged radiator, an air bubble in the system, or an air bubble right below the thermostat, so it never gets to open, and the air bubble stays there......those are a few things.
If the fan shroud is missing, the fan won't be able to pull any air through the radiator.
If the radiator is blocked, so air can't flow through it.
If the Radiator has mud in it (the outside being packed between all the fins from going through ALOT of mud), no air can pass, and will cause overheating.
it's a stock setup right?...no motor swaps or anything? or power adders, or lot sof performance parts in your motor?
Old Dec 2, 2006 | 11:35 AM
rebocardo's Avatar
rebocardo
Bad fan clutch could do it, for an off road truck flex fans are a better option because you get max. cooling at idle for $20-$30.
If your coolant is old or not mixed correctly that will cause overheating too.
Old Dec 2, 2006 | 12:06 PM
F1rocco-NY's Avatar
F1rocco-NY
Is there a shroud on it...Have you done a motor swap...Flex fan installed with new spacer.....The placement of the fan and shroud would need to be close to exact to stock....If the fan is too far in or out...It screws up the draw to cool the motor.....
Old Dec 9, 2006 | 05:04 PM
LedheadELH's Avatar
LedheadELH
actually the distance of the fan from the radiator and such doesn't make as big of a difference as you would think. I've done many motor swaps, and as long as the new fan is somewhat close the radiator, I run it that way!.....I've even put a 302 in a ranger that had a 2.8, and used the stock radiator, w/o a shroud, and never overheated.
Old Dec 10, 2006 | 05:20 AM
F1rocco-NY's Avatar
F1rocco-NY
It matters when on a trail ride or sitting idle....Maybe not as much with a smaller engine.....With no shroud you really are not pulling fresah air over the motor to cool it....Your moving the air but not directing its flow..........It really only matters if the noob returns to his or her post....I hate run away topics....
Old Dec 10, 2006 | 08:20 AM
LedheadELH's Avatar
LedheadELH
yea, a shroud is definetely good to have, but I would've had to make one for the ranger, and I really didn't care too, I hated that truck.....the only thing I liked about it was that it hauled ***, and burned one mean tire...well 2 cuz I welded it posi....but same thing
I didn't even notice he's been gone lol
Old Dec 10, 2006 | 09:56 AM
HomerWinzlow's Avatar
HomerWinzlow
I hate post and run topics too. Especially those you go to some special effort to find an answer. :|
I was going to suggest that just because the heater works doesnt mean the thermostat is good. Its just remaining closed like it should when cold. The heater works off bypass water flow so it would get hot first.
KDAVID1
Apr 25, 2014 06:23 PM
RobbyMartin
2004 - 2008 F150
Apr 15, 2013 01:00 AM
Masteratarms93
15
Jan 1, 2013 11:39 AM
pexhere
Aug 8, 2006 07:50 PM
joseph_m48075
Nov 5, 2003 01:34 AM
