heater servo HELP!!
Old Dec 10, 2006 | 03:53 PM
adamfrei's Avatar
adamfrei
Question heater servo HELP!!
i have a 89 f-150 302 . heater will not switch from defrost to vent...floor etc. i have read some of your other listings and have checked for broken lines to servo in and out of truck. i am not getting any vacuum to servo but i dont have any broken lines. what feeds the servo with vacuum?? also when i push the vacuum switch under glovebox vents work but i have no vacuum there either. any help would be greatly thanked!!!
Old Dec 10, 2006 | 07:17 PM
projectSHO89's Avatar
projectSHO89
Check the vacuum line that runs through the dash to the control head. If it breaks or cracks, you'll only get defrost.
Steve
Old Dec 10, 2006 | 07:59 PM
adamfrei's Avatar
adamfrei
thanks steve buttt i did check all the lines thats what has me confused they are all great. i know im missing something but cant figure out what. i traced them all to their "ports" and none of them are cracked or broke. any other ideas would be appericated
Old Dec 10, 2006 | 08:22 PM
stuart1's Avatar
stuart1
It is common
for a hinge on the blend door to break.
The entire heater assembly must be removed.
