DP Switch Mount
Old Nov 30, 2006 | 10:45 AM
jtharvey's Avatar
jtharvey
Originally Posted by Zephyr
Manual 4wd here, so I'm going to cut a hole in the blank-off plate where the ESOF switch would be & make a bracket to recess the F5 into the dash.
That would be pretty sweet. Flush mounted into the dash...nice idea.
Old Nov 30, 2006 | 11:50 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Mine is the older type (original type) large rotary ****.
Check my gallery for a look at it.
Old Nov 30, 2006 | 01:12 PM
Crash1040's Avatar
Crash1040
Thanks for everyones input. I love the idea of a pod mounted switch! Gonna try and hold out for something like that in the future. I hate to drill or cut the dash.
I think I'll just use the velcro for now and put it where the ESOF is. Temporary as far as I'm concerned. I idea of using a $.25 piece of velcro to mount my really expensive switch just doesn't sit right. I have a manual 4x4 so when and if I ever feel froggy enough I might cut me a hole to flush mount it. Good call on that one Zephyr.
Haven't signed up YET!, so I posted pictured of the switch in my gallery. I was really surprised at how small it is. Its seriously FOB sized. I was thinking it would be a little bigger.
Old Nov 30, 2006 | 09:31 PM
Pony Power's Avatar
Pony Power
I have the old style switch that I made a mounting plate for and installed it under the dash. I got tired of having to reach for it and now it is mounted on the top left side of the fuse box header. The fuse door close's without any trouble and the switch is real handy. Also no holes in the dash.
No picture of the new location yet.
Old Dec 1, 2006 | 02:27 PM
KrenzyRyan's Avatar
KrenzyRyan
Heres my setup, I like it, it seems to be the perfect spot. No drilling either. This is temporary until Jody comes out with his new mounting plate/mechanism that he promises to create (talks about it in the instructions that comes with the chip). I guess its suppose to be an accessory you can get for it.
Old Dec 1, 2006 | 02:38 PM
ron's power stroke's Avatar
ron's power stroke
just how i did mine till jody gets the mounting plate..but the flush mount into the dash sounded nice to... hmmmmm
Old Dec 1, 2006 | 05:07 PM
KrenzyRyan's Avatar
KrenzyRyan
That actually does sound pretty sweet. I just cringe when I think about cutting my dash though.
Old Dec 1, 2006 | 07:41 PM
ron's power stroke
i just went out and put my sp diesel TC lock and exhaust brake in..that has the same box as my DP does..looking at my oil presure and water temp gauge and the over the streering wheel dash pod. i found the pod comes down around that same place..i think i might cut that pod rather then my dash..hmmm what do you think??? i have this pod here..http://www.puredieselpower.com/catalog/ford-9904-gauge-instrument-bezel-mount-autometer-15003-p-550.html
Old Dec 1, 2006 | 08:07 PM
Zephyr's Avatar
Zephyr
Flush mounted into that pod (down where its mostly flat) would be pretty sweet.
BTW how do you like that pod ?
Do the gauges block much of the cluster?
I am thinking of getting it also, for my volt & water temp gauges.
Old Dec 1, 2006 | 08:11 PM
ron's power stroke
just below the gauge on both sides..i think there is just enouph room for it there.. i coud run the wires behind the pod down under the dash no holes no mess..i may try this..
lol havent gotten it in yet..i got to move my wait to start light cause it is right be hind the gauge..the other lights are not that big a deal..where the gauges set you cant see the lower corners about 2 1/2 inches in and 2 1/2 inches up
Old Dec 2, 2006 | 02:01 PM
KrenzyRyan's Avatar
KrenzyRyan
Sounds like an awesome idea to me
rich gill
Jul 8, 2009 07:37 AM
triskit16
64
Mar 25, 2009 03:28 PM
TNT in Round Rock
27
Jul 26, 2007 11:54 AM
BLK 96
Jan 2, 2007 07:34 AM
eric777
13
Mar 16, 2006 06:18 PM
