Oil Consumption Excessive?
Old Nov 19, 2006 | 10:21 AM
jerrycl's Avatar
jerrycl
Does anyone know what is excessive oil consumption on these 7.3's? I have a 01 and consumes 2 quarts every 3000 miles using Delo products and have a friend that only gets 1000 miles. I wasnt too worried about mine but his seems to excessive for my liking. My engine has 90 K on it. Not sure about his. And the other question is at that point of it using oil (add mark) is the oil breaking down and should it be changed or put 2 qts in her and keep driving till 5000 mi.?
Old Nov 19, 2006 | 10:49 AM
empiretc's Avatar
empiretc
I would be a little worried. If your truck still has warranty take it in.
How hard do you work it? Under heavy loads it would burn a little oil.
My truck doesnt burn a drop, and even after 5k the oil is still a nice honey color.
Old Nov 19, 2006 | 11:21 AM
JDS549's Avatar
JDS549
I have same engine and it is only used for light duty and sometimes a travel trailer. It did not use any oil for 125k miles and now has moved to about 1 qt. per 1000 miles. I can not see any leaks. I have noticed the blow by to the crankcase is worse than it used to be. It seems to be puffing when the oil fill cap is removed. This is not a real problem for me, but I wonder if it is leading to something worse. JDS549
Old Nov 19, 2006 | 11:45 AM
kbeefy's Avatar
kbeefy
maybe injector o-rings?
Old Nov 19, 2006 | 01:04 PM
JDS549's Avatar
JDS549
If it is o-rings, will it cause further problems or is the cost of oil the only thing? Another question, what is the general expection of life for this motor. JDS549
Old Nov 19, 2006 | 03:25 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Mine used to burn around 2 quarts every 5000 and I was told it was normal. Then one day when sitting in traffic I noticed a burnt oil smell. Upon further inspection I had a leak from the back of the turbo and was burning on the back of the engine, therefore I never noticed any drips. (in hindsight I would have looked a little harder before assuming it was normal.) Anyways, all is tight now and with 140,000 miles on her it does not use a drop. Just my 2 cents worth.
Old Dec 2, 2006 | 02:38 PM
just_waitin's Avatar
just_waitin
mine burns a liter in 5000km at 360000km and same thing i was told it was normal but it has done that since new, but i also run XD3 0-40 synthetic all year instant oil press at -30 gota love it
NicktheBrit
Jan 31, 2013 01:35 PM
Bunyon's_Ox
Apr 16, 2007 07:27 PM
broncoman66
Nov 11, 2006 08:06 AM
mkoonce
1997 - 2003 F150
Jul 20, 2004 09:11 PM
HzrInAz
13
Sep 13, 2003 06:30 PM
