A logical answer for this one?!
Old Nov 28, 2006 | 04:26 PM
mjlevi's Avatar
mjlevi
Every once in while a come across a post in a thread by someone who says the 6.0l diesel likes to be beat on, or driven hard!? ...can someone advise me of the theory and/or technical aspects of these statements..I have my ideas of what they may mean, but I just need to hear some other logic out there...thanks!
Old Nov 28, 2006 | 04:54 PM
03f350crew's Avatar
03f350crew
I've been wondering the same thing. Just saw someone say it earlier I for one am trying not to beat on it.
Old Nov 28, 2006 | 05:11 PM
mrxlh's Avatar
mrxlh
Plain and simple soot and carbon buildup in the EGR valve, and corrosion and soot buildup on the exhaust side of the turbo, causing vanes to stick. No one said to try to run a new 1/4 mile time from every stoplight, but letting it shift at or slightly above 3000 rpms on a weekly basis will keep above mentioned from happening.
Old Nov 28, 2006 | 05:23 PM
Maxium4x4's Avatar
Maxium4x4
It isn't your moms Buick....so stand on it once and awhile. Bring the turbo up to temperature to keep things clean. If you putz around town and leave the truck set for extended periods of time or idle for days on end, you will have problems.
Old Nov 28, 2006 | 05:25 PM
03f350crew's Avatar
03f350crew
Ahhh. I love it when something makes sense. I remember the users manual for a 1994 chrysler New Yorker saying once a month to floor it to keep injectors clean same idea I guess. Makes sense after seeing that picture of that Egr full of crudd in another thread.
Old Nov 28, 2006 | 05:54 PM
BowTieHatr's Avatar
BowTieHatr
plus it is a workhorse. most dont even work 'em. matts engine is the first crank i have heard of breaking (due to the rpm hes turning), and have seen/heard of pistons melting, but normal NOT TUNED trucks its a rareity. drive like you stole the darn thing, because i promise if it comes to see me, i have i size 14 thats not shy to go steppin!!
Old Nov 28, 2006 | 07:50 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I like to floor mine at least once daily. It's fun and it's good for the engine. Doesn't get much better than that!!!
Old Nov 28, 2006 | 08:00 PM
killaford's Avatar
killaford
mine is only size 12 but its on the floor more than its not.
Old Nov 29, 2006 | 02:54 PM
Bevis3's Avatar
Bevis3
I air mine out any chance i get....especially when passing a line of slow movers.
Old Nov 29, 2006 | 03:29 PM
TinyOne's Avatar
TinyOne
Thumbs up
While I agree with driving them hard. I dont agree that will keep the EGR clean.Or the turbo from Rusting up.(did not seize or stick). I have 29000+ MILES ON MY 2005 f350 LB CC DRW Lariat. 12,000 of that is pulling my 14000lb 5ver over hill and dale.The truck sees almost no idle time and sees daily tough driving.Pure stock other than reflashes no engine related work.(Sorry did have rusty turbo and clogged EGR cleaned.)
My .02 cents
Old Nov 29, 2006 | 06:11 PM
ford4lifer's Avatar
ford4lifer
Drove past a friend of mine in his new chev 2500 hd and guned it as I passed, he called me to say "what the hell was that jet engine sound and big puff of fossil fuel" I replied "my 747 kick'n your heat beat's ***!" lol
Old Nov 29, 2006 | 06:30 PM
BowTieHatr's Avatar
BowTieHatr
My .02 cents
nothing can stop a turbo from rusting unless you put it in a bubble and dry the air. as far as the egr, if it was clogged, then i would check my fuel source. bad fuel, or just low cetane will cause carbon no matter how you drive.
Old Nov 29, 2006 | 06:41 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
The ONLY way to prevent turbo rust is to dissasemble it, and have both the stripped center housing and turbine housing, along with the vanes and unison ring ceramic coated. You are staring at a 400-500 dollar bill, so its not worth to most people.
Old Nov 29, 2006 | 06:46 PM
BowTieHatr's Avatar
BowTieHatr
the ceramic coating wont last due to expansion rates and the tightness of the turbo.
Logical Heritic
Ford vs The Competition
45
Oct 20, 2014 06:38 PM
soupy1957
2009 - 2014 F150
66
Mar 12, 2013 09:00 PM
ReAX
Nov 7, 2006 07:25 PM
sipowitz
1997 - 2003 F150
Dec 17, 2003 05:04 PM
