Sponsored by: Real Truck
Q-logic Kick panels
Old Nov 5, 2006 | 08:23 PM
ReAX's Avatar
ReAX
Q-logic Kick panels
Does anyone have Q-logic Q-form kick panels in thier superduty? Pictures only show the pass side and I am curious how they fit around the e-brake pedal.
Old Nov 5, 2006 | 08:35 PM
Lonewolftx's Avatar
Lonewolftx
Unhappy Huh???
I have no idea what u r talking about so I have no idea if I do or not . . . .
Old Nov 5, 2006 | 08:38 PM
ReAX's Avatar
ReAX
Q-logic has replacement kick panels to mount stereo speakers. http://www.qlogic.ws/home/home.jsp
I want to see how low they seat the speaker and if it will interfere with the emergancy brake pedal befor I order a set. The before/after picture on thier website just doesn't look right for some reason.
Old Nov 5, 2006 | 08:49 PM
Cuda444's Avatar
Cuda444
Not entirely sure how accurate I am with this, as I was looking at them a few years ago and it's possible they have changed the design. But if I remember correctly the drivers side interferes with the e brake. Pretty sure that's the reason I didn't buy them as I have the stick shift and use my e-brake all the time.
Hopefully someone else will chime in with more definite info
Old Nov 5, 2006 | 08:58 PM
lariat79sc's Avatar
lariat79sc
I could see my size 12 steel toe doing wonders on them. What a waste of money imo.
Old Nov 5, 2006 | 09:20 PM
RACERX7775's Avatar
RACERX7775
Thumbs down q-forms
if you look close at the pic on their site, that is not a super duty or excursion door panel either. almost looks like a chebby truck. definately not a ford..
Old Nov 5, 2006 | 09:52 PM
jake00's Avatar
jake00
maybe try your local audio shop? I had them for an s10 and they did indeed interfere with the brake
Old Nov 5, 2006 | 10:00 PM
ReAX's Avatar
ReAX
Was it just rubbing or did it prevent you from engaging it?
Old Nov 6, 2006 | 01:02 PM
RACERX7775's Avatar
RACERX7775
either way, why would you want it if it "rubs"? i have done these in other cars and i have taken the assembly out, heated the arm and moved it to where it would clear everything, and then reinstalled it. works like a charm.
Old Nov 6, 2006 | 01:14 PM
akford351's Avatar
akford351
Why not get 5 1/4" comps and put them in the doors...
Make a mounting bracket the same size as the factory speaker and mount the comps on to that. There's a thread around here somewhere that shows an install... I did mine the same way.
Old Nov 6, 2006 | 04:41 PM
ReAX's Avatar
ReAX
I had thought about shimming the pedal out or bending it. Either way I should have them tomorrow.
Old Nov 6, 2006 | 11:23 PM
RACERX7775's Avatar
RACERX7775
q forms
you dont want to shim it because then you will run into problems because of the tension when you push it with your foot. and allignment problems with the cable. you dont have to bend it much. heat it, bend it slowly, then let it cool for a while..
Old Nov 7, 2006 | 07:18 AM
sofdchief's Avatar
sofdchief
If you want to know if it really fits, try calling Crutchfield (www.crutchfield.com). They tend to be more expensive than most car/home audio/video places, but they do extensive research prior to advertisement. They will also be able to tell you what, if any, additional components you will need to get your hands on for an easier install.
Also, if you are looking for custom fit applications for speakers, check out www.supercrewsound.com. They have a large selection of custom items for individual vehicles.
Old Nov 7, 2006 | 07:25 PM
tmann's Avatar
tmann
my buddy owns a car audio shop and ordered them for my 03 sd and they looked like **** and didn't fit or wouldn't hold my 6.5 alpine type x seperates so he ended up custom fitting them in the door
skidooman1990
Nov 13, 2014 01:20 PM
DieselBeast01
2004 - 2008 F150
Nov 3, 2011 11:16 PM
josh04hdf250
May 7, 2007 01:46 PM
BLEGOAT
Apr 30, 2004 02:42 AM
mrossirr
Apr 15, 2003 09:05 PM
