couple of issues; help!!!
Hey guys,
I research lots but somehow was not able to find propper info.
Ok, this weekend, i was installing my LCD car alarm, but ran into some trouble. I have an 05 f250 crew cab v8 gasoline ( no factory keyless entry or chip in key)
1 issue---I wired the siren fine however i want to wire also the horn of the truck. I did notice the horn wire (dark blue) in truck has 12v constant and in order for it to make sound a neg charge or ground needs to be applied. Now, how can i wire for it to sound? perhaps a relay? and if so how can i wire it? meaning 87 where , 30 where? in relay......the alarm output cable gives a positive charge when activates to siren......(would a flasher need to be installed?) how can i wire it? thanks sorry if its too much to ask....
2nd issue-i cannot find the positive trigger cable and negative trigger cable(someone told me might be on driver kick panel)
*can you provide me also with a link for a good wiring diagram of my truck? thanks
thanks let me know please.... looking to install remote start but that would come in after i get basics
3rd issue-i need to run a remote wire for my amps in truck, where can i run it off , so that when i turn on radio, it turns on the amps? (1st time running a remote wire sorry)
thanks a lot for all your help.........
Deltasoft.
Deltasoft.
12volts yellow (30A), lt grn/pur (30A) + ignition harness
Starter dk. green + ignition harness
Second Starter N/A
Ignition red/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray/yellow and red/black + ignition harness
Second Accessory dk. blue/lt. green + ignition harness
Keysense black/pink - ignition harness
Power Lock pink/yellow (w/o keyless) 5wi driver kick, door harness
Notes: Vehicles with keyless entry, the lock wire is white/red (-), in the driver kick, door harness or also at the VSM, gray plug, pin 3.
The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Power Unlock pink/lt. green (w/o keyless) 5wi driver kick, door harness
Notes: Vehicles with keyless entry, the unlock wire is black/white (-), in the driver kick, door harness or also at the VSM, gray plug, pin 2.
Vehicles with keyless entry the VSM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Lock Motor pink/black 5wi driver kick or VSM, gray plug, pin 1
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor red/orange 5wi driver kick or VSM, gray plug, pin 7
Parking Lights+ brown + switch or VSM, green plug, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light black/pink + back of fuse box, black 8 pin plug
Door Trigger use dome supervision wire
Dome Supervision black/lt. blue + pass kick or cluster, blu plg, pin26
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt green or red/yellow ac any ignition coil or fuel injector
Notes: On diesel vehicles the tach wire is lt. green/white in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - switch or cluster, blue plug, pin 18
Horn Trigger dk. blue - switch or VSM, green plug, pin 6
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Radio 12v
lt. green/purple
radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Trunk/Hatch Pin N/A
Hood Pin N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
No Type:
N/A
Part #: N/A
Notes:
Radio 12v
lt. green/purple
radio harness
Power Antenna N/A
newf350
1999 to 2016 Super Duty
12-19-2009 12:01 PM
