`79 460 Swap into F250
Hi guys,
I've another question from my dad, he has a `79 F-250 Ranger XLT, with a 400M and C6 transmission. He would like to swap in a 460 from the same year, and would like to know how far off the mounts are from eachother, would a 460 bolt right in with the proper original 460 mounts? Or is there going to be some kind of fabrication needed?
Any help is appreciated.
-Jeff-
-Jeff-
Is it a 4x4 or 4x2 ?
If it is a 4x2. he can get the 3-pc motor mounts off a 460 donor truck at a wrecker for a lot less money.
If it is a 4x4 he can get the motor mounts,rear sump oil pan from a 460 E-series van.
If you live in a hot climate......He will need to get a larger Radiator and special fan shroud as well.
Btw, tell your dad the 400 engine is just a 400 not a 400M
The M suffix belongs to the 351M.
There are at least 150 ...351M/400 - 460 swap threads on this forum.
goatchops
08-24-2005 05:23 PM
junkyardjeff
07-21-2005 09:49 AM
