1978 - 1996 Big Bronco
4" Lift
Old Nov 26, 2006 | 09:37 AM
69ford99's Avatar
69ford99
4" Lift
I was thinking about getting a 4" lift in a kit but was wondering if I could just do a shackle drop in the rear with 2" coils in the front with 2" spacers?
Old Nov 27, 2006 | 10:46 PM
ddubya61's Avatar
ddubya61
no you are better getting a kit.
there are ttb drop brackets and radius arm drop brackets. you will also need swaybar end links and drop pitman arm at a mininum
Old Nov 28, 2006 | 12:32 AM
aurgathor's Avatar
aurgathor
About 2" is the most you can do on the front without a lift kit.
In addition to what's listed above, you need longer brake lines and longer shocks, too.
Old Nov 28, 2006 | 02:19 PM
69ford99's Avatar
69ford99
I went ahead and bought the kit with the blocks for the rear but plan on upgrading to the leafsprings later. Will I need shims for the rear or not?
Old Nov 28, 2006 | 05:17 PM
MBBFord's Avatar
MBBFord
You could just not use the rear blocks, and do a shackle flip.
It'd be about the same as all leafs, and you wouldn't have axle wrap that you'd get with blocks.
What are you going to do about brake lines? There are the ss extended lines, but their pricey. If you wanted to stay on a budget, then you could get a 8" hard line and two connectors and just add it to your existing brake line.
jkufen
Bronco II
Apr 8, 2012 08:34 PM
Shwan_89HD
51
Mar 3, 2012 11:39 AM
homer4.2
Appearance & Dress-Up
Jan 29, 2005 05:26 PM
topo4u2
May 17, 2002 03:15 PM
motobub
Offroad & 4x4
Mar 22, 2002 08:25 AM
