Hey, I've got a Microchips Supertune that I installed several years ago on my 2000 7.3 PSD. I tried to use it to day to step back down to stock and can get no response from the unit. Any ideas?
I am using a superchips tuner #1705 in a 2000 7.3 crew cab dually 2wd. I can't tell much difference in fuel mileage. Where it shows up is in acceleration pulling my trailer. I have only used in tow mode set up for any length of time. I tried the max hp once (not towing) just for a comparison for less than 50 miles and did not like the sound of the engine. My intake has been upgraded but nothing has been done to the exhaust system. I think you will see greater benefits if the exhaust is changed to 4"or larger.
Thanks for the help - my lighter fuse was blown. Next question - can I reset this truck to the Stock map and use the tuner on a different 7.3-equipped Super Duty?
As long as the tuner has the calibration for it. The label on the back should have a year range, if the other SD is within that range and the stock tune was unloaded from it, yes.
