Aerostar Ford Aerostar
aerostar engine pull tips and tricks
Old Nov 25, 2006 | 05:04 PM
sicdefused's Avatar
sicdefused
Im ready to drop a engine on a 3.0 litre aerostar van. please share your experiences and all the tips and tricks to make the job run smooth.
Old Nov 25, 2006 | 05:15 PM
thefarelaneman's Avatar
thefarelaneman
If this is the first time that you have ever pulled an engine be prepared to spend alot of time. I have never removed one but know that you have to have floor lift and a strong stand to attach it to when it (and the front stearing units and wheels etc come down.Dont attempt this without a service manual.
Old Nov 25, 2006 | 05:47 PM
copper_90680's Avatar
copper_90680
Jay, a.k.a. JTHill24 has a nice write up on how to pull a 3.0L engine out from the front. I did the same for my 4.0L and it's similar. Jay has a write up somewhere on the Web. You may have to wait until he provides the link.
There is no need to drop the engine through the bottom. That's too much work.
By the way, welcome to our FTE forum
Old Nov 25, 2006 | 05:56 PM
thefarelaneman
Why would the haynes manual say you had to remove it from the front?
Old Nov 25, 2006 | 06:22 PM
96_4wdr's Avatar
96_4wdr
Jay's photo essay on pulling a 3L is so good and detailed that i've saved the link
click here
he makes it easy...details all the in's and outs plus the don't does
Old Nov 25, 2006 | 06:34 PM
JTHill24's Avatar
JTHill24
All you need to do is ask.......
http://jthill.herringtontech.net/
JaY
Old Nov 25, 2006 | 06:36 PM
JTHill24's Avatar
JTHill24
When I get the bench cleaned up I plan on doing a A4LD.
I got ahold of one I can use to tear apart and put back together.
Will have loads of pictures.
JaY
Old Nov 25, 2006 | 07:37 PM
copper_90680
I'm afraid I don't understand your message
I thought all manuals said to drop it through the bottom?
Old Nov 25, 2006 | 09:18 PM
thefarelaneman
I ment to say "Why does my haynes manual say you got to remove it from the bottom" copper said the best way was from the front and I just wondered . Im all for the easy way
Old Nov 25, 2006 | 09:26 PM
JTHill24's Avatar
JTHill24
Because if you can pull it from the front then the Dealers can't charge you for a 8-12hr job. Thats the time their books says for the job to pull it.
JaY
Old Nov 26, 2006 | 12:23 AM
copper_90680
The Haynes and Chilton manuals all said you must remove it from the bottom.
Ford's service manual says you can do it either way. I followed Jay's instructions and pulled it out the front, very easily I might add.
Old Nov 26, 2006 | 11:21 AM
Bear River's Avatar
Bear River
Former ******
You do realize that Haynes owns Chiltons right?
Old Nov 26, 2006 | 01:33 PM
96_4wdr's Avatar
96_4wdr
and GM may own Ford soon!
doesn't mean I'm going to be driving a Corvette with a Blue Oval on the front
Old Nov 26, 2006 | 03:53 PM
thefarelaneman
Im happy to learn that replacing the engine can be done without a floor lift. Up to now this was the only repair I figured I would never be able to do.
Old Nov 26, 2006 | 04:04 PM
sicdefused's Avatar
sicdefused
is it easier to pull the engine with the transmission or without, and should one unbolt the rack and pinion steering?
