1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
loud shuddering vibration noise when acclerating
Old 11-25-2006, 04:11 PM
superpelly's Avatar
superpelly
superpelly is offline
2000 EB. When pulling my trailer and 2 four wheelers I hear this loud kind-of grinding noise. More like shuttering vibration noise coming from the front mid section area. If I accelerate slow to 70mph the problem is not very noticible. But if I accelerate quickly ( from 50mph to 70mph) the noise and vibration is real bad. Any ideas?
Old 11-25-2006, 05:19 PM
kwegman003's Avatar
kwegman003
kwegman003 is offline
transmission would be my first guess but im not too sure...does it happen when your not towing or no
Old 11-25-2006, 06:36 PM
superpelly's Avatar
superpelly
yes, but not as bad, . This only happens 55mph or more and going up hill, I guess when i'm losing power, when I have to get heavy on the accelerater.
Old 11-25-2006, 10:03 PM
aagitch's Avatar
aagitch
aagitch is offline
What size engine and how much weight are you pulling? Does it help if you have the overdrive off?
Old 11-25-2006, 11:52 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
MazdaRangerGuyInSTL is offline
You might have a bit of an engine miss... buy a coil pack and swap it around one at a time until it's fixed.
Good luck
Old 11-26-2006, 10:08 AM
superpelly's Avatar
superpelly
5.4l, The sound and shuttering sounds like it comes from the front somewhere. I do take it out of over drive. i'm only pulling about 2500lbs, including the trailer. Sounds like a drive-train problem. If i ease into my acceleration going 55mph to 70mph no problem. But when I'm going up hill and loose power and get heavy on the acclerater (55mph to 70mph) the loud noise and shutter from front area starts and then when I reach my constant speed, the problem stops.
Old 11-26-2006, 10:30 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Could be a bad/intermittent COP or spark plug,but could also be TCC shudder.
I'm going to guess that you've got the 4R100 trans,and if that's the case,it's unlikely that it's TCC shudder-the 4R70W's tend to have issues with that,not the 4R100's.
JL
rubersole
09-03-2006 03:39 PM
norrislaketn
06-13-2006 01:02 PM
andy blossy
Escape & Escape Hybrid
12-20-2005 12:20 AM
gustaf
11-19-2005 08:26 AM
sportrac2001
03-15-2004 11:09 PM
Quick Reply: loud shuddering vibration noise when acclerating
