Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2002 loud escape when cold acceleration
Old Feb 1, 2005 | 03:26 AM
andy blossy's Avatar
andy blossy
Doea anyone have a handle on a real loud resonant noise that occurs at colder temperatures when accelerating? It seems to be loudest at 2500 rpms. Is not an exhaust leak. I have heard ,cold body-engine mounts that fail to dampen the vibration. I am thinking harmonic balancer? This is a loud sound, and can prevent you from hearing a passenger conversation, that is how loud it can be on a cold day. When I leave my warm garage it is fine but as the car cools down the noise starts. Acompanied by a vibration in the 5 speed shift handle and seats etc.
Old Feb 1, 2005 | 07:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Dec 6, 2005 | 06:50 PM
90blue5.0's Avatar
90blue5.0
This is the same problem I am having right now. Tempature has been around -25C.
Old Dec 13, 2005 | 05:42 PM
andy blossy
escape noise
Hello I am working on it-going in to the dealer,again, tomorrow. I do not think they know how to fix it. May very well be the freezing resonator and for that there is not much of a fix. Will let you know. Any leads on your end? Andy B.
Old Dec 14, 2005 | 12:39 AM
tonyford's Avatar
tonyford
Well at that temperature I would be making loud noises also!..that's about
-13F.
Old Dec 14, 2005 | 08:26 AM
90blue5.0's Avatar
90blue5.0
It seems to be fine as soon as the temprature outside is anywhere above -20C. I don't think that it is any cause for concern.
Old Dec 20, 2005 | 12:20 AM
andy blossy
Hello ,About the Escape noise and other problems issue. It is highly influenced by cold, ALaska is pretty cold, so it is a big problem. Anyway, the next port of call on the repair log, is to drill drain holes in the muffler body. It seems the factory overlooked this item. Most all cars now have these things to allow for drainage . As water becomes a bigger and bigger component of cleaner exhaust emissions, I guess you just have to adjust. I'll withhold comment until the system has a chance to deep freeze and see what happens. Yours truly, Andy B
W7PSK
6.7L Power Stroke Diesel
May 9, 2022 11:04 PM
Jayslow
1997 - 2003 F150
Sep 4, 2014 07:39 PM
volfreak
1997 - 2003 F150
Oct 21, 2007 11:06 PM
superpelly
Nov 26, 2006 10:30 AM
sportrac2001
Mar 15, 2004 11:09 PM
