Help I Gotta Short
Old Nov 30, 2006 | 12:08 PM
  #31
jnsprigg's Avatar
jnsprigg
Good news bad news... I started back at the fuse box and found a big yellow wire with a bad splice. I cut off the butt connector and respliced by soldering and covering with heat shrink. This wire is associated with the dash light circuit so I had an easy indicator as long as the light switch was on. After I corrected the splice the truck started right up and ran well but I noticed that if I wiggled the same yellow wire the dash lights would flicker ... I think this is a loose connection at the fuse box itself. I decided I could live with intermittent dash lights for a while and tried to put the headlight switch/fusebox back in the dash (truck still running) but the hot wire to the cigarette lighter was in the way so I disconnected it and accidentally shorted it. Well the truck died immediately and now everything is dead again. I checked and all the fuses are still good. So I decided rather than start throwing thins in frustration, I'd stop and eat lunch and get back to it later. As I mentioned earlier, I got a new (used) harness coming anyday and I think I just need to wait and try to put it in and start fresh.
Old Nov 30, 2006 | 12:50 PM
  #32
airharley's Avatar
airharley
A wire melted somewhere in between the battery and cigarette lighter. Do the light trick I wrote about in my earlier post to find the bad dash lights and no power issue.
Old Nov 30, 2006 | 02:19 PM
  #33
jnsprigg's Avatar
jnsprigg
Yeah I figured it's melted a wire somewhere and I'm thinking it might be at the soldered splice. The whole fuse bus has been spliced in. Some of the splices are soldered and others are crimped.
billdevaul
Feb 1, 2013 12:13 AM
irlfan360
22
Dec 31, 2010 08:03 PM
xfordtech
Sep 12, 2005 12:02 PM
Turbored
Sep 28, 2004 02:19 PM
oldesailor
May 8, 2004 10:11 PM
